Old 02-13-2012, 01:18 PM   #1
la nomade's Avatar
2018 22' Sport
stanfordville , New York
Can not blow my horn
it happens once in a while,i check the fuse in the glove compartement and its o.k.i think it has something to do with the compresser ,but i forgot what to do to adjust,and solve the problem..i am on the rd...and parked right now near a airstream number 10379,the king you pull....and spotted another one on fl rt 75 going south,i am going north...any ideas as to how to get my horn to work????
la nomade is offline   Reply With Quote
Old 02-13-2012, 06:28 PM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Martine, are you certain that you have 'air' horns on your Classic? Mine appear to be air horns but are actually electric horns, no compressor involved. Know that getting to roof is almost impossible for you while traveling. My only thought would be a loose wire on the roof next to the horns. Enjoy your travels back home. Be safe.
Thanks, Derek
Old 02-13-2012, 07:38 PM   #3
2005 30' Classic
Images: 12
Ok, not that I can help you with your problem, but the thread title made me chuckle! You see, I was always taught that it is not appropriate for someone to toot his own horn....
GetOutDoors is offline   Reply With Quote
Old 02-13-2012, 08:21 PM   #4
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
ha ha!
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 02-15-2012, 07:10 AM   #5
la nomade's Avatar
2018 22' Sport
Thanks, Derek
there are no exposed wires ..none...i still think its something to ajust on the compresser..will ask around the campground.am at little talbot..so lovely ..there is a bambi parked ,no truck ..no one there,it looks vert well kept.cheers.m
Old 02-16-2012, 05:12 PM   #6
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
horn problem
Check under the hood for a loose wire under the air holding tank, mine is a white wire that comes unclipped and runs to a solenoid or a relay - not sure what it's really called
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 02-17-2012, 09:55 PM   #7
Silverton , Colorado
Had the reverse happen to us...honking 'goodbye' at a rally, and it stuck...for about 20 seconds/hours...finally hit the button kinda hard in frustration or embarassment(the button didn't care) and it hasn't worked since...long way to a short point is it could be a contact or wire under the button.m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 02-18-2012, 06:12 AM   #8
la nomade's Avatar
2018 22' Sport
i found the wire etc nothing is loose,i still think its something to do with the compresser..and ,but,i had to reconnect a wire for the turning signal the green one,probably shewed up by a ????and found another long loose wire,have no idea what its from..will have it all checked out when i get home ...thank you for your creative ideas...prefer to have it not work then have the problem michael and tracy had!!!!!!i am on my way to n.y...have to wait out sundays storm..do not like to drive in bad weather....and oh...the salt on the rd.....m
Old 02-18-2012, 06:48 AM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
"Can not blow my horn"
Also got hooked by the title.
No MH here but I've had air horns on my Burb's for years.
In our 95, because of how the compressor and tank were mounted in the engine compartment, there was a re-occurring problem, no workie when needed or stuck on when not.
It always turned out to be the air-valve switch,(solenoid), very similar to this one, it got so I kept a spare in the toolbox.
The set-up is in a better location in the 06,(dryer), and it's no longer a problem.
POI...that site has lots of other set-up's also.
Got my switch from JC Whit though.
FWIW..... after looking at the photo in your gallery, the question...are they actually "air horns"? You did say you found the compressor...right.?
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 02-19-2012, 09:25 AM   #10
la nomade's Avatar
2018 22' Sport
can not blow my horn
Bob,the compresser sits in the back in the last compartment under the bed..it sometimes goes on when i first turn on the engine after sitting there for a while,recently it has not ...i am not 100% sure they are air horns but,way back when the same problem occurred,this mecanic went to the compresser and adjusted something....and it worked,it could be electrical,as i said,when i get home i will check it out...thanks.
Old 02-19-2012, 02:31 PM   #11
crazeevw's Avatar
Martine,
I truly believe you have the electric 'air' horns. The compressor at rear of coach is for the rear suspension air bags. Still, not seeing for myself, I could be wrong.
My thoughts are that it could be your horn switch on the steering wheel.
How's your trip home so far? Derek
Old 02-20-2012, 06:13 AM   #12
la nomade's Avatar
2018 22' Sport
derek,thank you for asking,i have been waiting out the big snow storm that hit nort carolina& virginia in a campground in Santeen sc...i will leave today,but if rds are wet with salt or badly plowed i will pull off the rd and wait...somewhere..till it dries up...spotted several Bambies on their way south on 95 ...you are most probably right about the horn...m
Old 02-20-2012, 08:59 AM   #13
crazeevw's Avatar
Be safe whatever you do. Know that the North Carolina Welcome Station has a LARGE parking area if you make it that far. Worst part about snow storms in SC or NC is that they are not prepared with the proper vehicles to plow the roads. Since they don't really average much snow each year, that's understandable. Santee is a beautiful area though!
Derek
Old 04-22-2012, 08:31 AM   #14
la nomade's Avatar
2018 22' Sport
Horn
Derek
questions about how the horn works..looked all over the airstr.manuel,HORN is not even listed...at the garage just now while fixing the batteries problem,they put in a different horn,like a regular car horn...that will not do..i want to restore the original sound....is there maybe a defective part i can get from airstr.???but mostly would like to know how it works...seems to be connected to same fuse as radio...fuse say Horn.....its all so complicated!!!!
Can not blow my horn la nomade Classic Motorhomes 31 07-30-2012 06:45 AM
New refrig-Not real cold Rich of SCal Refrigerators 18 06-03-2012 08:31 PM
A couple questions about my new toy TPickerl 1981 Excella II 3 04-05-2012 11:17 PM
