Old 06-25-2012, 09:38 PM   #29
RBonney's Avatar
1983 27' Excella
1990 34.5' Airstream 345
Spring Lake , Michigan
My horn started goin off at times on its own it's a long time till u run out of air. It always happened at wrong times. So I pulled fuse all the time I parked now it just blows fuse as soon as I put it in. I miss tooting my horn
RBonney is offline   Reply With Quote
Old 06-25-2012, 11:58 PM   #30
Santa Cruz , California
Images: 12
I don't know about the 1990 but the 1983 has what looks like air horns are actually electric. There is a horn relay near the fuse block. Do you hear a click when you push the horn button? Also, the wire from the block to the horn is green in mine ... I'd put my chip on that wire getting disturbed when you were fixing the other problem.
dljosephson is offline   Reply With Quote
Old 06-26-2012, 04:56 AM   #31
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Check the wiring for the air solenoid valve, it would stick at times on ours, always at the rong time.
If the valve isn't stuck open then the wiring for the horn relay may be the culprit. Also with a tilt steering wheel the wiring can ground when the wheel is turned or tilted.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-30-2012, 06:45 AM   #32
Brighton , sussex
My new electric horn is not working either. I do have electric/air horns fitted on the roof but they are not wired in yet. I have a simple dual car horn fitted as my mechanic was a bit lazy. He is no longer my mechanic.
Questions. Where is the fuse for the horn on my 310? Under the dash? If so which one?
It has new relays and wiring and I started tilting the wheel recently for comfort. How many wires go the horn on the wheel and where does the earth go to? I have a bunch of earths on top of the sheet metal above the engine to the left of the radio.
Loving Life, Chicks, Cars and Mummas Grits baby
montreal is offline   Reply With Quote
Can not blow my horn la nomade Classic Motorhomes 31 07-30-2012 06:45 AM
New refrig-Not real cold Rich of SCal Refrigerators 18 06-03-2012 08:31 PM
A couple questions about my new toy TPickerl 1981 Excella II 3 04-05-2012 11:17 PM
