Old 06-08-2016, 04:20 PM   #1
1979 28' Airstream Excella 28
grants Pass , Oregon
Can I cut a new hole in the side of 79 AS MH?
Hi there my friends. My hubby and I are knee deep into changing a 1979 AS Motor-home with the center bath and twin beds in the rear. I want to change the twin bed thing and put in what would be about a king size bed. We already took out the night stand and are about ready to re-frame the bed, but we will lose that precious storage space that is beside the generator, and the isle space. So I was thinking that if we could cut a hole (square) into that passenger rear panel beside the generator and have a hatch cover made, could we make that space a storage area for his golf clubs or our tabletop barbeque? I don't know where the support panels are or is there a major concern about cutting into the rear panel?
Would appreciate any thoughts about this.
ASmotoring79 is offline   Reply With Quote
Old 06-08-2016, 05:16 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Cutting a hole into an Airstream moho is the easy part.......making sure it won't leak is the tough part.
You need to first post pictures inside and outside with what panel you wish to cut, giving as much info on dimensions for possible hatch size and measurements to nearest walls, ribs (look at rivets on outside for location) and generator. Then hopefully someone will have a hatch that could work for you. Once you have the hatch, then you will know what size hole to cut.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 06-08-2016, 06:23 PM   #3
1995 36' Classic 36
Ludington , Michigan
You can do a better than factory job with one of these:
Their claims that they cut anything are BS but they do a beautiful job on aluminum. Plunge cut, forward, backwards... They make very smooth accurate cuts. No catching, jumping...
Kota is offline   Reply With Quote
Old 06-08-2016, 06:56 PM   #4
I like using a tool like this Porter Cable Multi Tool. I use it to cut just about anything on my Argosy. Works like a charm!
Like Tony said, the first thing you need to figure out is the size opening you want and then figure out what size hatch can be found that will do the job. I've got a smaller hatch available, probably not big enough for a large golf bag but it might suffice.
Anyway, pictures and dimensions would be very helpful for us to see what you're contemplating.
By the way, welcome to Airforums!
Old 06-08-2016, 07:15 PM   #5
Dazed and Confused
Isuzusweet's Avatar
I should add to make special note of ANY electrical wires anywhere near the area you want to cut as you're near the Genny and a Fein saw, or as Brad calls it, Multi Tool, will cut into a cable or wire in a heartbeat.
When I cut my rear air vent, I swear to almighty I didn't breath as there were bundles of 12 V and 110 Volt wires on both sides of the cut and I had to cut across them, as well as along the wire..
Oh, like Brad said, welcome to the forums.
Cheers
Tony
Old 06-08-2016, 07:17 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Your property. Cut away.
MICHAEL
Old 06-08-2016, 07:25 PM   #7
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
This is the 79 rear bath with the shower on the inside, but as you can see its just air to the left of the genny compartment.
I like to use my trusted Bosch Sabre saw with the newest and finest metal cutting blade. First map it out with blue masking tape to have a perfect line to follow, AFTER you have the new hatch in your hands for measurements. You do want an original Airstream type door with the frame thats riveted.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 06-08-2016, 07:30 PM   #8
Airstream Driver
1997 30' Excella
Images: 51
But then I wonder why people don't keep their awesome twin beds for day time use and just use this simple method to turn the twins into a huge king bed. Best of both worlds and no storage lost.
And yes, welcome to this forum!
ID:	264042   Click image for larger version
1996 Airstream B190
AIR #13
Old 06-08-2016, 07:57 PM   #9
Dazed and Confused
Isuzusweet's Avatar
Peter
It's the reason I love my rear convertible lounge; two sofa's during the day and a king size bed for sleeping.
Looks like ASmotoring79 is in great hands!
Cheers
Tony
Old 06-08-2016, 08:10 PM   #10
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by Isuzusweet View Post
Peter
Cheers
Tony
Tony, I didn't know you had the cool rear lounge (with fold away table to boot) That must be the finest layout of all, IMHO. I think that the rear full size bed is such a waste of precious space.
ID:	264045   Click image for larger version
1996 Airstream B190
AIR #13
Old 06-09-2016, 04:53 AM   #11
Dazed and Confused
Isuzusweet's Avatar
Yup, can seat 13 comfortably in mine plus the only bed I've ever slept in that I can't touch the bottom or top.
Sorry for thread hijack but OP is away taking measurements.
Cheers
Tony
Old 06-09-2016, 05:00 AM   #12
Airstream Driver
1997 30' Excella
Images: 51
Cheers
Tony
I don't think its a hijack, Tony. I always appreciate seeing all the options possible when doing a major remodel like this. Especially when I am almost done executing my brilliant idea
1996 Airstream B190
AIR #13
Old 06-09-2016, 10:36 AM   #13
Tampatomgirl
1990 34' Excella
Zephyrhills , Florida
I have the same setup in my '90 Excella. Personally, i have no use for twin beds. I plan to build a base with a lift for a queen mattress and use the space below for storage.
Tampatomgirl is offline   Reply With Quote
Old 06-09-2016, 05:54 PM   #14
Airstream Driver
1997 30' Excella
Images: 51
original equipment access doors are available in different sizes
http://airstreamsupply.com/New-Airst...door-100679-01
1996 Airstream B190
AIR #13
Drop the belly pan or cut an access hole? Breezin' General Repair Forum 8 06-16-2014 11:13 PM
Side to side leveling: can I use the stabilizer jacks? iAirstream Jacks, Stabilizers, Lifting and Leveling 4 08-17-2007 07:33 PM
AC hole cut-out framing silver 67 Furnaces, Heaters, Fireplaces & Air Conditioning 8 10-05-2006 10:53 AM
PO cut a hole in interior bathroom wall to fit the new toilet. Sregon 1967 Overlander 7 08-18-2006 09:30 AM
hole has been cut in floor under frig silver 67 Refrigerators 4 08-16-2004 06:53 AM
