Old 06-12-2016, 07:58 AM   #15
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Originally Posted by PeterH-Airstreamer View Post
But then I wonder why people don't keep their awesome twin beds for day time use and just use this simple method to turn the twins into a huge king bed. Best of both worlds and no storage lost.
And yes, welcome to this forum!
Peter,
What type of supports go underneath the middle plywood bridge?
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 06-12-2016, 08:13 AM   #16
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
There are generally a few of those access panels listed on E-bay. If you don't find one check back in a week or so.
I personally would not cut the whole opening at once. I would cut a 4" square hole , then reach in there and see what you find. If that looks good I would cut out a few more inches, then look again. There are many surprises lurking behind that skin. If you start small you may find a problem but, still have time to relocate your opening to make it work.
Oh yea, Welcome to the insanity!
Gregsch is offline   Reply With Quote
Old 06-12-2016, 10:23 AM   #17
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Originally Posted by Tap View Post
Peter,
I would imaging a couple of cleats have been added to the edges of the bed and the plywood spans between the cleats.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 06-12-2016, 01:46 PM   #18
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Peter,
I don't use a support , since the space is just 24" or so. Depends on the thickness of the plywood, the foam cushions and the person sleeping on it.
During the day the plywood can be stored under the twins mattresses the extra foam cushions can be used as a back for your lounge.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Drop the belly pan or cut an access hole? Breezin' General Repair Forum 8 06-16-2014 11:13 PM
Side to side leveling: can I use the stabilizer jacks? iAirstream Jacks, Stabilizers, Lifting and Leveling 4 08-17-2007 07:33 PM
AC hole cut-out framing silver 67 Furnaces, Heaters, Fireplaces & Air Conditioning 8 10-05-2006 10:53 AM
PO cut a hole in interior bathroom wall to fit the new toilet. Sregon 1967 Overlander 7 08-18-2006 09:30 AM
hole has been cut in floor under frig silver 67 Refrigerators 4 08-16-2004 06:53 AM
