Old 08-02-2015, 03:41 AM   #1
1982 31' Airstream 310
Henniker , New Hampshire
Broken down. Looking for help
I am a new guy here. I have a 1982 310 motorhome with a 454 gas engine. I am currently in South Bend Indiana with a blown motor. If anyone is from the area and can refer me to a reputable mechanic, I would be grateful. I am a long way from my home in New Hampshire and could use some advice from a local.
1982 310 motorhome 502
Henniker New Hampshire
chiefair is offline   Reply With Quote
Old 08-02-2015, 04:50 AM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Sorry to hear. I don't know the area. Do you have AAA, Coachnet or Good Sams?
Also try googling in your area and call a few shops. They'll tell you if they're capable or not. Indiana is the heart of RV manufacturing - I'm sure there must be good service teams there. Good luck!
Old 08-02-2015, 05:05 AM   #3
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
What makes you think you have a blown engine ??? If the engine is shot you basically have three options, maybe four. The first would be a Airstream dealer for repair. The second would be to call Jasper and get a recommended shop near your location. The fourth, which I would do, is have the Airstream transported back home and repair it yourself. Oh and the third option???? sell it as is where is....if you're done.
bobmiller1 is offline   Reply With Quote
Old 08-02-2015, 05:05 AM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I was at a KOA there the night before last. The KOA map has an ad for Master Tech RV 866-895-4456 and Gates of Granger 574-237-4101. They don't specifically mention motor rebuilds, but they may or may be able to refer you to someone.
Good luck
2012 Dodge Durango Hemi/AWD
Old 08-02-2015, 06:22 AM   #5
Thanks for the quick replies. I was on I-80 and happened to be looking at my gauges when the oil pressure suddenly dropped off to 20 psi. Almost immediately after that it went bang. I quickly got it into neutral and shut it off. I could see the telltale white smoke from the exhaust in my mirror. I coasted to the shoulder. Now it is locked in a tow yard and I am in a hotel.
1982 310 motorhome 454
Old 08-02-2015, 06:28 AM   #6
Good luck
Thanks for the potential contacts.
Old 08-02-2015, 06:46 AM   #7
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
You might be better to look for a truck shop than an RV shop.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 08-02-2015, 07:36 AM   #8
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
You actually have two issues chiefair; finding a shop to repair the engine that is also capable of removing the engine from the labyrinth that is a classic motorhome engine bay.
Finding someone able to repair or exchange a big block Chevy should not be difficult, but we need Brad or another of the 310 guys to chip in on how difficult it is to get the engine out/rebuild in place.
I was quoted two weeks labor to change an engine on an older Argosy because the entire front end has to be un-riveted, hopefully access is easier on a 310.....if not start to arrange shipping.
martin300662 is offline   Reply With Quote
Old 08-02-2015, 07:53 AM   #9
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Sorry to hear, ChiefAir.
This is what I would do:
I would first try to get a local mechanic to assess the damage, if possible.
You are just under 1000 miles from home. Get a quote from https://www.uship.com/ right now and then add up all the expenses you would have, if you have the motor repaired or replaced in South Bend.
Hotel, rental car, loss of wages , food etc, but not counting the motor work.
Having a motor replaced at an unknown pace does not sound very appealing, since you will encounter many other issues that will need to be addressed.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-02-2015, 08:53 AM   #10
Thank you all for good input. I am hoping to arrange shipping through uship. I can't access the MH until tomorrow. I will get better measurements then so I can fill out the uship form. I believe mine is 10'8" tall but I don't know the actual width or length. I know the 310 is a 31' MH but I have never measured it to confirm. Can't post to uship until I get accurate measures.
Old 08-02-2015, 10:19 AM   #11
Airstream Driver
1997 30' Excella
Images: 51
here are my dimensions 83 310
8'6" with mirrors extending, 32'3" bumper to bumper and 10'4" with coleman mach A/C's.
You can get away with just 8' width, if you would fold your mirrors in, in case it would make a difference
1996 Airstream B190
AIR #13
Old 08-02-2015, 11:04 AM   #12
mayco's Avatar
champaign , Illinois
Absolute drag, sorry for your situation. We have an '82 310 also but its a diesel. Time and time again I read here on the forums about the 454 giving up at 50 to 60 thousands miles. Must just be a lot of vehicle for that motor. Reading the classified adds its common to see "454 engine replaced at 50,000 miles" or 60, or whatever. So should those who own a gasser just build an engine replacement into their maintenance budget? Just asking, not trying to start a gas vs diesel debate here.
For instance, if you are looking to buy one of these Classic AS motorhomes, you see one with very low mileage (say 45000) should you just assume an engine replacement is in your not too distant future and work that into the offer you might make on the rig. Maintenance of course comes into play as a variable. Just thinking about it and was discusding it with my lovely wife this morning (boring her to death Im sure)
Anyway back to the problem at hand, it will be interesting for all of us to know what your shipping quote is if youre willing to share that. Could be applied in the purchase of a rig thats far away and not road worthy enogh to get it back home.
I believe that motor has to be pulled out the front of the rig. So once you get it home and are getting estimates, you may want to consider pulling all the items you can to get back to the motor yourself. I did that when I had to have my harmonic balancer replaced and Im sure I cut several hours of shop time off the bill. Its all bolted together (no rivets) and its just a matter of going step by step removing the parts AND keeping good notes and pictures of the diasembly. It also gets you aquainted real fast with the componants of your rig. So if your are willing and able to give it a go you can save yourself some significant dough-ra-me by doing that part yourself.
http://www.airforums.com/forums/atta...2&d=1377686163
Thats the front end of my rig after removing the grill, trans cooler, radiator, and some other misc items. Of course the bumper and some plastic body parts would need removed also for an engine pull, but not too much more. Its worth considerring as a DIY if you want to save yourself some money.
If this is a life long rig for you, it may be worth just considerring a diesel swap. Its very involved and would take a great deal of research and more expensive that a gas engine replacement. But if this is your rig for life.........you MAY want to give it at least some passing consideration.
Regardless, hang in there. Heres hoping that the ship home is uneventful and the engine swap goes as well as it can.
Keep us posted, great resources here on the forum.
Mike
mayco is offline   Reply With Quote
Old 08-02-2015, 11:13 AM   #13
Keen amature
1975 20' Argosy 20
Chestfield , Kent
If you can get your rig back to NE chiefair, you also have options like (Cummins 6BT Swaps) doing an engine swap to diesel....
Old 08-02-2015, 11:15 AM   #14
belen , New Mexico
454
Never bought a motorhome because of that 454. Almost got an 80 something cause it had a ford 460. Would love a diesel. Isn't there an AS factory in Indiana?
alantbird is offline   Reply With Quote
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Awnings: are they really up/down/up/down ... Belbein On The Road... 6 06-08-2014 01:55 PM
Vintage rig broken down/SoCal scotty449 On The Road... 1 07-03-2008 01:22 PM
Broken down classic motorhome. guy99 Classic Motorhomes 1 01-29-2006 09:33 AM
anyone broken down and tried airmark tools Ed Starman Cleaning, Stripping & Polishing 50 04-25-2005 12:57 PM
