Old 08-04-2015, 05:36 PM   #43
r carl's Avatar
Lin , Ne
And for a new one this has forged crank, rods, and pistons.
454 HO Big Block Crate Engine | Chevrolet
Old 08-04-2015, 06:13 PM   #44
1982 31' Airstream 310
Henniker , New Hampshire
Brad, Thanks again for taking the time to help me out. With a trailer height of 42" I would be 14' tall. Too high to be legal. I think we will make the low bed work. If I remember correctly, the generator exhaust is the lowest hanging obstacle behind the axle. The trailer steps up 14". I can block up the rear wheels enough so the 9 feet behind the axle will clear that 14" step and still be legal height.
Keith
1982 310 motorhome 454
Henniker New Hampshire
1982 310 motorhome 502
chiefair is offline   Reply With Quote
Old 08-05-2015, 05:46 AM   #45
Keith
Dang, that's right. The 310 is definitely taller than an Argosy. I transported my 74 Argosy on a 42" deck trailer and it just cleared the 13'6" height requirement (at least that's what the trucker hoped!) by an inch or so.
Sorry about that
I think you're right about the genset exhaust being the only thing hanging down at the rear of the coach.
Old 08-05-2015, 07:52 PM   #46
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Broken down. Looking for help
IMHO, forged components for an engine that makes less than 300 HP is overkill... WAY overkill.
Two bolt, cast 454s will most always go more than 100K miles without blowing up.
Dollar for dollar, the cheaper engines are a better deal for RV duty.
No pricing on that link, I am thinking probably 8K to 12k?
Old 08-05-2015, 07:56 PM   #47
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It is a lot cheaper than I thought....
I would think about it for $5,800...
http://m.summitracing.com/parts/nal-12568774
Old 08-05-2015, 09:00 PM   #48
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
With all due respect, have you ever owned a Classic motorhome with a 454 7.4L?
1) Depending on the size moho and how hilly the terrain the moho is driven on, it wouldn't be surprising to hear a 454 in a 345 blowing up with only 50,000 miles on it after being driven through mountainous or hilly terrain. The very first 345 I looked at had 130,000 miles and he was on his third motor, fourth transmission. One motor blew in Tennessee; with our dollar at the time being worth .65 cents US, it was cheaper for him to float the coach to Canada for the engine replacement.
2) The big cost of an engine replacement is the labour to pull and replace the engine. It can easily surpass or be equal to the cost of the engine rebuild or replacement, so spending money on a cheap engine that is not specced out to pull 15,000+ lbs is courting disaster, a lot sooner than later.
IMHO unless you do the work yourself and enjoy banging knuckles in the very tight engine space of a Classic motorhome, I would strongly suggest you buy a very strongly built motor specced out with a RV cam as a replacement.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 08-05-2015, 09:18 PM   #49
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Motorhome? No. Never owned one,,,
But I do own and have owned plenty of 454 equipped trucks that we routinely load to around 26,000 pounds gross.
Just conveying my experience.
I also have noticed that it takes a lot of people a long, long, time to put 100,000 miles on a motorhome.
What is different from the 454s in these motorhomes than the typical 454s that went in the same era one tons?
I don't know, but I suspect nothing. As far as I know, forged components were not offered in passenger 454s at least from the mid seventies.
If these motorhomes had used a real truck engine, they would have used a 427 tall deck engine.
Old 08-09-2015, 06:29 AM   #50
Thanks to some good friends, my 310 has made it back home. Click image for larger version
Name:	ImageUploadedByAirstream Forums1439123321.531751.jpg
I appreciate the help And advice from everyone here.
Old 08-09-2015, 07:00 AM   #51
Awesome pic!
Old 08-09-2015, 07:07 AM   #52
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Check with chevy dealer for complete new engine,usually the cheapest route to go, that is what we did with the truck engines when a 427 give out...
Old 08-09-2015, 07:21 AM   #53
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Thanks to some good friends, my 310 has made it back home. Attachment 245039
Congrats!! Do you mind sharing what kind of bids you got from Uship for the 1000 mile trip?
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-09-2015, 07:37 AM   #54
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I would say the first task would be to pull the top of the engine and keep your fingers crossed it is something repairable in place....if not start dismantling to get the engine out.
Whether you rebuild (to a motorhome spec), drop in a used motor (and you are more any welcome to the 454 in my donor but would have to come take it outt) or drop in a Chevy Performance crate engine (454 HO Big Block Crate Engine) is totally down to budget, but lower budget = higher risk of failure (and a repeat situation) down the road.
martin300662 is offline   Reply With Quote
Old 08-09-2015, 09:21 AM   #55
Whatever you do, it needs to be a 4 bolt main block. They are just stronger. Mine had a 6,000 mile old Jasper reman unit in it when I bought it. We will see if it survives miles or my itch to put a Cummins 6bt in there and double my mpg! There is a company out here in CA that builds a very nice BBC motor that is in the $2500 range. It makes 400hp and 500ftlb but that is on a more car based cam... I bet they could put an RV cam it it.. I will post the link when I am in front of my computer.
Old 08-09-2015, 10:05 AM   #56
halftimer's Avatar
irving , Texas
Pay the extra bucks for a jasper engine have warranty on motor and labor nationwide
halftimer is offline   Reply With Quote
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Awnings: are they really up/down/up/down ... Belbein On The Road... 6 06-08-2014 01:55 PM
Vintage rig broken down/SoCal scotty449 On The Road... 1 07-03-2008 01:22 PM
Broken down classic motorhome. guy99 Classic Motorhomes 1 01-29-2006 09:33 AM
anyone broken down and tried airmark tools Ed Starman Cleaning, Stripping & Polishing 50 04-25-2005 12:57 PM
