Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 06-30-2009, 05:40 PM   #1
swanky's Avatar
Grosse Pointe Park , Michigan
broke down near mothership
The highlights: loud noise from below. Able to pull over just past the white line where we stayed from 7 pm to midnight. Spent what little was left of the night (2-7 am) at AS factory. No gear would engage--anyone want to guess??
The kids and I are at a hotel. The moho is at a shop in Wapakaneta. No new seats. We hope to get home tomorrow.
So I will let you all play Dr House and diagnose her if you'd like. I only have the iPhone so forgive my typos.
Adventure number three is not a success yet.
Audrey
1982 280 Turbo Diesel Limited
Classic Motorhome
"A Silver Lining" or Silvie for short
"Ah, well. I'm off to get my life sustaining supplies - cornmeal and gunpowder, hamhocks and guitar strings."
swanky is offline   Reply With Quote
Old 06-30-2009, 07:39 PM   #2
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Does it make any noise when put into gear?
Mike Leary is offline   Reply With Quote
Old 06-30-2009, 08:41 PM   #3
swanky's Avatar
No unusual noise. It revs normally as if in neutral or park regardless of gear. Even reverse. The shop called and he found something else broken but related to the orig issue.
Audrey
Classic Motorhome
Old 06-30-2009, 09:52 PM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I had a similar experience last summer. It was a broken flex plate, the device that connects the engines crankshaft to the torque converter. After the trans was removed it was discovered that the trans was not correctly aligned to the engine. There had been recent engine work and the plate that adapts the trans to the Isuzu had not been properly aligned when the engine was reinstalled. They had also left out some of the alignment dowels.
If you have the same problem make sure they do a precision alignment check before it goes back together. On mine it turned out the previous owner had recently had a broken flex plate and the shop just put a new plate in. Obviously it didn't last very long.
Good luck, Dan
Old 06-30-2009, 10:13 PM   #5
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Check the tranny fluid level. GM's don't go anywhere when there's not enough fluid.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 06-30-2009, 10:36 PM   #6
Astrodokk's Avatar
Seattle , WA
Same thing with me, although Aamco said it was the flywheel, which is on manual transmissions. They replaced the flexplate and all is well. It had some teeth broken off.
Too bad about your seats. Hope they hold them for you.
2000 Ford E-350 Super Duty 418ci/6.8L Triton V10 21’ Chinook Concourse XL
Astrodokk is offline   Reply With Quote
Old 07-01-2009, 05:25 PM   #7
swanky's Avatar
Broken Fly wheel, torque converter
Yes, you were correct, mostly. The fly wheel broke. Then when he was in there, discovered the torque converter (?) was also broken. The factory had supplied two aluminum brackets (at least I think they did, they were on the floor of the moho when the repair guy got the vehicle) that the guy did not install but that he recommends we install. They are supposed to secure the trans/engine connection better. I have to find someone to do that. The guy said they need to be drilled and bolted, he guessed about a two hour job. It has survived 27 years without the brackets but this guy says the reason the fly wheel broke and the other thing cracked was because of the stress put on them by the lack of the brackets.
Are we talking about the same thing? Flex plate?
It was a long 48 hours, but we got home safely. She ran fine and we are supposed to go to the other side of the state tomorrow evening for the long weekend. I am going to try to find someone to get these brackets on tomorrow before we leave but I'm afraid I won't be able to explain what I need well enough over the phone. What kind of shop do I call? Transmission repair or diesel engine repair or what?
As for the seats, we have them home now. They are lined up in the motorhome right now. Sadly, we have spent more than we planned to spend installing the seats to get her up and running so that little upgrade will have to wait a while.
Hubby wants to sell the seats we bought to help offset the fly wheel repair. He may have a point. We'll see. Maybe we just need a long weekend in the middle of Sleeping Bear Dunes National Lakeshore to figure it all out.
Ah well...
Audrey
Classic Motorhome
Goin' to the Mothership! Chuck On The Road... 23 09-26-2008 06:25 PM
off to see the mothership!!! runningbarre On The Road... 12 07-25-2008 09:51 AM
If you go to Mothership in Jackson Center... Bambi_Bandit Off Topic Forum 23 06-29-2008 10:13 PM
2006 Classic Trip to the Mothership Dover 2006 - 2010 Classic (all lengths) 1 06-20-2007 09:12 PM
