bright lights relay
Does anyone know where the bright lights relay is located in a 1981 Excella motor home?
I replaced both the light switch on the dash, and the foot switch with no effect.
The problem is that the regular light works fine, but when I press the foot switch to activate the brights, all the lights come on for a few seconds- say 10 seconds, then they all are intermittent random flashing, all 4 at the same time flash together. It is like it is right on the edge of a failing relay or something. I traced the wires and they enter the large loom behind the fuse panel under the dash, but then head out of the firewall. I tried moving wires to see if it is a loose wire, but that has not effect.
also, does anyone know what these 2 components are for circled in red?( if photo attached.
Thanks for your help.
