Old 09-20-2007, 06:33 PM   #29
jagcb750's Avatar
1986 30' Airstream 300
B , Louisiana
Here is a pic of the master cylinder I just installed
The original Master Cylinder was leaking underneath it. I thought I would post a pic of where the Master Cylinder is located for the newbs.
This is a pic taken just above the driver's side left front tire. There is a cover plate removed for easy access. It usually isn't that easy to see or get to.
jagcb750 is offline   Reply With Quote
Old 09-06-2009, 02:44 PM   #30
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
brake job 101
On our return trip from the beach the other week, our brake warning light came on, so took note and planned for an inspection. On the way out of Panama City as soon as we got to speed we'd hit another red light. My wife was following in the truck and called to say I'm smoking. The passenger side dually brakes were indeed very hot. Nothing to do but head on and only use the brakes when absolutely necessary, eventually you do come to a halt when coasting
Anyway, this is my first time lifting something this heavy and attempting a brake job. Info so far in this thread amongst others is really helping.
See attached pictures. These pads look ok to me, but why would they cause so much heat? Is it worth getting the master cylinder reconditioned while its off, and what about the reservoir, a good cleaning or replacement. Do I pump the brake pedal with the engine running?
ID:	86693   Click image for larger version
ID:	86695   Click image for larger version
elbundi is offline   Reply With Quote
Old 09-06-2009, 05:57 PM   #31
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Andy, did you retract the caliper prior to removing it? How tight where the pads? A dragging brake might indicate a problem with the caliper, brake line or master cyl.
That you got a brake light might mean master cyl. so check it out first. Did you verify the fluid in the chambers?
Parts aren't a problem as NAPA is a good source as is Mill Supply.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 09-07-2009, 03:58 PM   #32
elbundi's Avatar
Leesburg , Georgia
Hey Glen
The calipers weren't that tight so I used a C clamp and a piece of wood to reract the piston after removal.
Well I found one problem, see attached. Pitiful! After a year and half of ownership I have no excuse.
Anyway, it took the whole 32oz bottle to bleed all the yucky old stuff. It'll be next weekend before I can do the other 3, but the brake warning light is now off. I went for a spin round the block, alas the rear dual brake did get hot and started to smoke a little. Hmm
Old 09-07-2009, 06:20 PM   #33
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Hmmmm is right...
The fact that you're missing a bunch of brake fluid should make a little light go on.... not on the dash board though.
Perhaps a new master cyl. is in order.
Have you checked the brake lines?
If the caliper retracted in the normal manner then I would not suspect the caliper as the first area of concern but a brake line that is expanding or a master that is not pumping enough pressure.
As it is only the one side have you looked at the other to make sure you're getting action there? A clean disc will tell the tale.
So, it's not my money so I'll spend the big bucks and replace the master and take a hard look at the brake lines to the rear brakes. And hey, while you're at it the stuffed caliper can't cost that much more.
Old 09-07-2009, 07:31 PM   #34
richinny's Avatar
2011 34' Classic
could that smoke be leaking brake fluid?
Ricky
Old 09-07-2009, 08:07 PM   #35
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
There is a good chance that the left side caliper is frozen and with no fluid going to the front brakes, that poor right side caliper is doing all the work stopping the rig. This would get it hot real quick.
Old 09-08-2009, 08:15 AM   #36
1965 24' Tradewind
slaughters , Kentucky
Electric brakes on 345!
The information about the braking system on the 345 is very good; however, I would like to add information about the electric tag axle brakes.
I do not believe they every worked on my '84 345. The hydraulic control was next to useless. I replaced it with an electonic brake control unit from NAPA; next, to make a long story short, you must ground the electronic unit very well (as instructed) or it will not work properly. AND, although the wheel magnets had force, they were inadequate. I replaced them with more powerful wheel magnets and now they work. Then you must adjust the brake control as instructed to not "burn rubber" with the tag axle electric brakes. And, now I have brakes!!!
Joe Gooch, Slaughters, KY--
joegooch is offline   Reply With Quote
Old 09-08-2009, 11:32 AM   #37
1965 24' Tradewind
For Jag and brake problems on 345!
The information already given about the brakes is excellent! Let me add my experiences about the electric tag axle brakes. First, I found the original hydraulic brake control unit to be worse than useless; I replaced it with a NAPA electronic control unit; secondly, the NAPA unit must be grounded as instructed or it will not work; thirdly, the original magnets on my brakes checked out all right but finally I found they were simply not powerful enough to lock the wheels and I replaced them with more powerful magnets; now the tag axle brakes are powerful and you have to adjust the NAPA control unit as instructed to avoid leaving a trail of rubber.
In my opinion the tag axle brakes on my 1984 345 never worked a day in their life; the magnets were too weak; the hydraulic control unit was useless.
Now, are the brakes adequate? Yes, unless you tailgate; you must remember that this 345 behemouth is a loaded truck; trucks need more time to stop.
Hope this helps,
Joe in Slaughters, KY
Old 11-25-2009, 04:33 PM   #38
1991 35' Airstream 350
Windsor , North Carolina
Brakes--Thanks to all
Well, you've all done very well, again!!
Went down to the Zeppelin tonight to turn on the refer, stow some stuff, and check to see that the new coil still works--MSD Blaster SS, lasted less than 2 years--but I digress. Started fine--then I put my foot on the brake pedal. It went to the floor, and the brake light on the dash came on.
What to do? Looked in the engine compartment. No reservoir. Looked under the "hood." No reservoir. Where's the bloody thing? Moreover, what's my bloody problem?
Did I mention that its been raining for days-and I don't really want to crawl under the truck in the dark? Or that I've got a six hour drive tomorrow?
I found this thread in the forum, and I would guess that I'll be able to sort this out in the morning (although I may have to buy stock in the brake fluid company before I'm finished).
Thanks to all--even though you did not know the help you were!!
Rob
ralley is offline   Reply With Quote
Old 11-25-2009, 06:06 PM   #39
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Hey ralley, it took me a while to find it too. The reservoir is behind the front driver's tire. you can access it from the outside of the front wheel well. There may be an access panel in front of it. It's practically mounted over the frame. Pretend you're going to change the cylinder 1 spark plug from underneath & you'll bump your left elbow on it.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Winterizing a 345 Motor Home winner Airstream Motorhome Forums 11 09-29-2007 12:56 AM
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
Electric Brake Wiring JW84345 Brakes & Brake Controllers 3 03-26-2002 09:40 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
