Originally Posted by 1987_345 I am trying to tow a 1995 Jeep Wrangler behind my 345 and am having a devil of a time with the blinkers. I have verified that plug on the MH is correct and the wiring I tapped into at the back of the Jeep is correct. When all is plugged in the tail lights work, the brake lights work, but when either left or right blinker is engaged on the Mh, the brake lights on MH and Jeep on left and right sides blikk dimly but like flashers. Any ideas? |
Hi, I'm not sure exactly what you are saying, but the way I hear it, you need to replace your flasher unit to a truck or electronic type. Your flasher is too weak to handle the extra Jeep bulbs, so it flashes too fast.
Or make sure that the turn switch lever and the hazard light switch is in the off/neutral position. [on your Jeep]
Or diodes like previous poster suggested.
