Old 11-23-2011, 04:09 PM   #1
Sacramento , California
Big electrical problems in a 345
My '86 345 quit getting AC power. The reset switch in the breaker box in the rear driver's side cabinet would not function. Tests revealed there was power at the inlet outside in the cabinet, but not at the wires going into the breaker box.
Today, since I have been without power for awhile, the DC lights and fan started to wane.
I started the generator. Then it ocurred to me that the best way to charge the batteries was to start the motor. I let it run for about twenty minutes. When I turned the motor off it sounded as if the generator was turning off too, even though I had turned it off previously. Then there was a loud pop. When I retried the engine the "hot" light came on.
The generator does not supply any AC power either (don't know if it did before or not).
Have tested and reset the breaker under the dinette seat.
Is there a Univolt somewhere or something I have overlooked above?
It appears that some of the wiring was gerry rigged from the pole input as two wires come up from under the rig and up to the cabinets.
Where to start? Any help appreiated.
silverdream2 is offline   Reply With Quote
Old 11-23-2011, 04:14 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Sounds like the transfer switch that transfers power between the shoreline and generator is not closing in either position. In the few motorhomes I have been in, this switch is under the bed.
Good Luck,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 11-23-2011, 04:25 PM   #3
1982 28' Airstream 280
Redwood City , California
Good Luck,
Also sounds like the shore/generator transfer switch to me. This switch automatically switches the power between shore power and the generator...will switch to generator if generator is producing voltage. The two wires you mention might be the Romeo wire from your shore cable and the other feeding from the generator. They should both go into the switch and then one Romeo wire to you 110 volt circuit panel. Your Univolt (converter) should have nothing to do with your problem.
If your switch is old then it could like like mine did before I replaced it recently. It was corroded and had burnt wires! Very dangerous indeed!
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 11-23-2011, 04:28 PM   #4
Oops, wrong photo. Here is my old switch and my new electric I put in...
ID:	145878   Click image for larger version
Old 11-23-2011, 06:37 PM   #5
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Did you reset the circuit breakers on the side of the generator? Should be 2 breakers.
The best way to charge the batteries when the converter is not working (no AC power) is to use a battery charger.
I'm not sure where you tested for power but if you have power coming into the RV but not making it to the breaker box it goes to the transfer switch before the breaker box.
Garry
Old 11-24-2011, 08:51 AM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
My generator also has 10 amp fuse near the breaker.
Old 11-26-2011, 01:30 PM   #7
more info
The electrical problems started after two new Fantastic fans were installed. Today after taking off the inside cover it is clear the wires in the ceiling were pierced by screws holding the covers. They test good for continuity though.
I do have the old style transfer switch picturedf (thanks!) but there is no power coming to it anywhere.
Would like to know where the shore power goes after coming into the rig?
Where is the Univolt; it says there is a GFI on it in the manual.
Any further places to look?
Thank you so much!
Old 11-26-2011, 06:05 PM   #8
more info again
Some progress... the generator powers the outlets, but not the AC or microwave, etc.
The shore line still does not work at all.
How does one go about replacing the transfer box with an electric switch?
Thanks.
Old 11-27-2011, 02:05 AM   #9
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
The Univolt in my 89 345LE is under the kitchen area. The main breaker box for the moho is along the floor, and I'm guessing the Univolt is behind the breaker box. I'll look today and take some photos if you need some.
Thanks, Derek
Old 11-27-2011, 04:13 PM   #10
1995 36' Classic 36
Ludington , Michigan
What is the brand of your power transfer switch. Mine works but sometimes I have to go to the bedroom and stomp my foot to get the generator to come online. I've hit it with some contact cleaner and lube but still having issues.
Kota is offline   Reply With Quote
Old 11-27-2011, 06:27 PM   #11
3 Dog Nite's Avatar
Cleveland , Tennessee
The "Univolt" is located in my galley area like in crazeevw's MH. It's a EnerGeniuos though. A small pop, then sparks is how mine died. Click here for photos of location. Yes crazeevw, the Univolt is behind the power distribution center.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 11-27-2011, 06:40 PM   #12
I installed a ATS 301 Line/Generator Switch from Parallax Power Supply. I got it online but will have to find the receipt to find out where.
Old 11-27-2011, 06:43 PM   #13
Dont forget, unless I am wrong, the feed from the genset or shore is directed by the switch over the galley...
Old 11-27-2011, 06:47 PM   #14
Probably got it from Dyersonline
http://www.dyersonline.com/parallax-...er-switch.html
electrical power, univolt, 120 volt
Big Bend TX must see and do Lumatic On The Road... 5 11-13-2011 07:03 PM
How big is too big? unit13 All Argosy Trailers 3 05-16-2011 09:28 AM
boondocking in Big Bend Park Texas greenisabel Boondocking 3 03-30-2011 06:54 AM
Electrical? Water heater? Water pump? robwok 1960 - 1964 Overlander 6 02-09-2011 11:53 AM
