Old 08-02-2016, 07:50 PM   #1
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
Belts
OK all, I'm looking at the GM service manual from the sticky thread trying to figure out belt numbers. I have the belt part number page in hand, but the lash up diagram is completely different than mine. I have a serpentine belt for the alternator and water pump, and V belts for the power steering and AC. Anyone else have the same configuration and can provide me with the AC belt number? Thanks!
gaiaenviro is offline   Reply With Quote
Old 08-05-2016, 10:55 PM   #2
gaiaenviro's Avatar
Belts
So, the belts I bought are incorrect, and being the hard head that I am, now get to replace the power steering pump, again. I'll keep you posted with parts numbers when I get them figured out. Seems the power steering belt should be 41.5" long and the AC 61" plus. The serpentine is pretty straightforward. Stay tuned, more details next week....
-Bill
Old 08-05-2016, 10:59 PM   #3
gaiaenviro's Avatar
Belts
Also, along this line, I've noticed some squeaking in my front end over the last 6 months mostly when the front suspension flexes. Tonight when removing the PS pump I noticed that 3 of the 4 bolts that hold the sway bar to the frame were missing (accounting for the squeak). It's an unusual thing to check, but look at them next time your under the front end to be safe.....
-Bill
Old 06-20-2017, 04:26 PM   #4
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
This, along with the Motorhome chassis guide is a good resource for belts. Some of the Motorhome belts were slightly different to the P30 belts, so care should be taken to ensure they sit correctly in the pulleys.
http://www.carquestprofessionals.com...tage_2006_.pdf
Boom Sounds is offline   Reply With Quote
Old 06-21-2017, 07:58 AM   #5
Also use the unit repair manual and exploded parts diagrams. I've found you can sometimes identify replacement GM belts. I'm close inspection, these look to be an exact match whereas other belts can have small tolerances. I'm not sure of the extent to which this matters
Fan/alternator belts pjude Classic Motorhomes 4 06-28-2008 02:06 PM
Adding seat belts and dinette bed Ellwallhome General Motorhome Topics 2 07-27-2004 09:57 AM
Dayco Belts AccessMaster Airstream Motorhome Forums 5 10-01-2003 06:51 AM
belts roskoe Mechanics Corner - Engines, Transmission & More... 1 08-16-2003 10:50 AM
1988 -345 Tires and Seat Belts MacInDaBox Airstream Motorhome Forums 15 12-12-2002 10:14 AM
