Old 07-01-2013, 11:03 AM   #1
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Battery tray solenoid replacement - is this best option?
Hi all,
Is this the correct part to replace the solenoid on the back of the battery tray on a 1991 250 Classic?
many thanks
Nick
Sure Power Battery Separator
Part #: 1315-200
http://www.allbatterysalesandservice.com/browse.cfm/4,5736.html
The Sure Power Battery Separator is designed for use in multi-battery applications as a excessive loading while allowing auxiliary batteries to be charged. The Sure Power Battery Separator has two basic operational characteristics.
Boom Sounds is offline   Reply With Quote
Old 07-01-2013, 11:15 AM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Originally Posted by Boom Sounds View Post
Hi all,
many thanks
Nick
Part #: 1315-200
Might be a bit overkill. You might consider this one. Cole Hersee: 12 Volt Insulated Solenoid with Silver Contacts - (Part#: 24143)
Cheers, Dan
~ Margaret Thatcher ~
Old 07-02-2013, 03:56 PM   #3
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
If price is an issue (it always is for me), this one is cheaper although it has mixed reviews:
Amazon.com: Customer Reviews: Tekonsha 7000 12 Volt 3 Terminal Battery Isolator
Waipio Rim is offline   Reply With Quote
Old 07-02-2013, 05:59 PM   #4
The thing I don't like is they give you no specs. The Cole Hersee is continuous duty and also rated at 200 amps. They do have a 80 amp continuous duty unit for $23 but you are linking the 2 house batteries to the start battery so 80 amp might be a little underrated. Also probably don't need a continuous duty for starting but that doesn't seem to be an issue price wise.
I would hope that the starting battery should start the engine by itself but Airstream seemed to think there was a need for the back up so they installed the solenoid. Good luck.
Cheers, Dan
Old 07-02-2013, 11:18 PM   #5
Thanks - I like the look of the cole hersee over the other brands, including the Intellitec. I noticed Cole Hersee have actually released an updated version which has some other advantages (see below). I'm trying to find a supplier
http://www.colehersee.com/home/item/cat/168/24213-01/
The silver-tungsten contacts provide the best available conductivity and are more weld-resistant than standard silver contacts, company officials said, adding that the design minimizes arcing and contact oxidation, therefore always maintaining high performance. The solenoids are designed for universal use for loads up to 200 amps. Several environmentally-sealed options are available, including encapsulated solenoids 24213-01 which withstand moisture and dust to IP66 standards. Where vehicle vibration may be a problem, model 24213-01 features potted internal windings for added protection of coil leads and studs.
Old 07-03-2013, 08:23 AM   #6
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
Are you talking about the solenoids that disconnect your coach and or chassie systems? If so look up Intellitec on the web. The store and operate switch is inside the entrance door and the solenoid(s) are attached to the back of the battery tray.
raveson is offline   Reply With Quote
Old 07-11-2013, 07:04 AM   #7
Hi all,
Just to clarify, I'm trying to replace the Cole Hersee solenoid with aux starter which is attached to the rear of the battery tray on my 250 MH.
The surepower 2303 is the blue finned isolator is inside the engine bay which is fine.
I had hoped to replace the Cole Hersee battery tray solenoid/aux starter with the following product:
Sure Power Battery Separator - (1315-200) ~ All Battery Sales and Service
My understanding is that the Sure Power: 12V 200A Battery Separator - Bi-Directional w/ Aux Start will replace the faulty Cole Hersee battery tray solenoid, still give me the aux start function and offer the added benefit of charging my chassis battery when on plugged in power (or Solar) in the future.
Would someone be so kind as to confirm that I have understood this correctly?
many thanks
Nick
Old 07-11-2013, 12:33 PM   #8
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
I think you have it figured out. In fact I bookmarked that link you posted for when I need to replace mine. Thanks. Steve
t7389sg is offline   Reply With Quote
Old 07-12-2013, 05:26 AM   #9
