Old 10-29-2009, 07:17 PM   #1
Battery Tray Repair
I knew our battery tray was deteriorating but I guess I didn't realize just how bad it was until I crawled underneath to take a peak. From the pictures you can see what I'm talking about.
Name:	Battery box 1.JPG
ID:	89945 Click image for larger version
Name:	Battery Box 2.JPG
I removed the battery tray this evening to start prepping it for some much needed repair. Plans are to remove the remains of the floor, sandblast all exposed and rusty areas, fabricate a new floor, paint and then reinstall in the coach.
On a previous post by a forum member they mentioned that when they repaired the floor of their battery tray they made it a couple of inches deeper. I'm looking into doing the same thing. I'll make a sketch of what I would like to do and have a local fabricator bend up the pieces for me and I'll weld them in place.
One thing I'm wondering about is the large 2" diameter holes in the bottom of the tray. Are those really necessary? I would think they would allow a lot of road grime to enter the compartment.
While the tray is out I'm going to go through all of the electrical connections in the area as they were all looking a little cruddy.
I'll post again as progress is made.
Old 10-30-2009, 09:42 AM   #2
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Now that is one of my next projects but I have not had the nerve to crawl under and Look !!!!
The Holes may be ??? For venting battery's acid gasses and also for draining fluid purposes ???? Venting, Cooling and fresh air would be my Number 1 guess !!!
John H. is offline   Reply With Quote
Old 10-30-2009, 11:54 AM   #3
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Brad,
Good idea to deepen the tray. This should allow you to install golf cart batteries should you ever wish to. I relocated my chassis battery and squeezed 4 marine/deep cycle (Costco grp 27, I think) house batteries into the battery drawer. I would have used golf cart batteries but they were too tall.
On my rig there are cutoff switches, solenoids and terminals mounted on the inboard side of the battery drawer. I'd love to see a picture of how your 310 wiring is configured.
When I repaired the floor of my battery drawer I covered the large holes and just drilled a couple of 1/2" drain holes.
Attachment 89945 Attachment 89946
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 10-30-2009, 06:15 PM   #4
MaryContrary's Avatar
on the road , CA and OR this summer!
Images: 41
ooh 4 batteries!...i wish we had welded up ours to be deeper
the handles scrape the top and it's still hard to close. those terminals are a little too close to the frame
the slides you can get at mcmaster carr
and we coated the interior with truck liner rubberized spray
and yesh.. i would be very very interested also at your wiring at the back of the battery box
i have a bicycle tire intertube wrapped around one of the solenoids that i cant find a replacement for ...anywhere
i'm gonna have to try a p-30 scrapyard
that contraption is shorting if it touches the frame....but on a light note the bike tire works well
my AS Moho blog
for the love of all vehicles round and shiny
MaryContrary is offline   Reply With Quote
Old 10-30-2009, 06:19 PM   #5
Images: 41
i have to warn you guys...the PO of my 310 dragged the batteries and box a few feet 'cause the box rusted out.
hence my weird wiring and electrical nightmares
...ohh halloween is right around the corner
my AS Moho blog
Old 10-30-2009, 08:23 PM   #6
Mary, I noticed our batteries hanging part way out of the box on our return trip from Chicago this past weekend. Hence the desire to fix it ASAP!
Fortunately there is nothing wrong with our drawer slides. I do need to clean and lube them but they should be fine. Only the very bottom of the box is bad. The sides and the bottom flanges appear to be ok.
As for the holes and venting. I wouldn't think venting would be an issue since the top of the tray is open and air flow should be sufficient. Personally I'm inclined to make small holes like Guy did. It would be easier to add holes later if need be than it would be to try and plug them .
We've been considering golf cart batteries. I guess I'll pull the seat on our Ezgo and do some measuring tomorrow just to see how much depth I would have to add.
Guy, to where did you relocate your starting battery?
I was also considering using the rubberized liner for inside the box but have heard horror stories about the rubber trapping moisture and rusting out anyway. I would imagine its all in the prep work.
Here is a picture of the wiring on the backside of our drawer: Click image for larger version
Name:	Battery Tray Rear.JPG
We only have one solenoid on the back of ours and I think it is for when you need a temporary boost from the coach batteries to start the engine. Which reminds me, that didn't seem to work the last time I tried it. That's one of the many reasons I want to go through all of the connections while they are exposed.
Tomorrow (weather permitting) I'll take some pictures of the tray area with it out. You can easily see all of the wiring right now.
Old 10-30-2009, 08:30 PM   #7
John,
I drove right buy your place about 20 times in the past year. We moved from Jefferson Ar to Richmond Ky late last fall and I spent the last 11 months moving everything that was in my shop. The movers moved the house and garage for us but I had to deal with the shop, all the tools and our collection of vehicles by myself.
The Cumberland Parkway is a beautiful drive and was pretty much the one part of the trip that I actually enjoyed.
Old 10-30-2009, 08:38 PM   #8
richinny's Avatar
2011 34' Classic
some other nice member posted this place for switches/solenoids.
Cole Hersee Co.
Ricky
Old 10-31-2009, 07:33 AM   #9
Images: 13
John,
How about that Brad, we have some friends in Richmond that have boats in our marina. State Dock marina, Jamestown is off SR-127 south of the parkway that you traveled. there is a lovely Ky Park camp ground and state lodge here also if you would ever like to camp and Boat we could fix you up.
sounds like you get good use out of your airstream and enjoy her. we get up 75 every week, sometimes 2 to 3 times and Bob Evans or steak and shake are our stops. Lots of new growth there in Richmond
I hope you enjoy the Area Brad
Old 10-31-2009, 10:48 AM   #10
guy99's Avatar
Images: 16
I rigged a battery tray and supports just forward of the battery drawer. It is a pain to get the battery in and out (you have to lay on your back and lift/slide it into place) but it did give me room for four house batteries.
I only have one solenoid on my battery drawer too (its for the boost function you describe) but I also have two switches, two power posts, and a shunt.
I have mostly "0" and "00" wiring so its pretty crowded.
Old 10-31-2009, 11:48 AM   #11
Images: 13
Could the Tool Box, just behind the battery tray be used for the engine, start battery. Leaving the tray for House batteries ???
Old 10-31-2009, 12:49 PM   #12
guy99's Avatar
Images: 16
I imagine it could although I would put in beefier drawer slides.
In my case, I use that tool box for my 30 amp extension, pneumatic hoses, and fresh water hoses, filters, and spare parts.
Old 10-31-2009, 03:29 PM   #13
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Battery Box
Brad,
Once you get the new battery box fabricated take it to the local LineX dealer and have it sprayed. I used to get rust around the exposed storage boxes water connection box and aft sliding drawer on my Classic and the LineX put a stop to it.
By the way welcome to the Bluegrass State!! There are many beautiful things to see and do within easy reach of Richmond. If you have ever thought about becoming a WBCCI member the Kentucky Unit is very active and a great group of people to hang out with. You can view their web site at www.kentucky.wbcci.net
fltlevel510 is offline   Reply With Quote
Old 10-31-2009, 05:50 PM   #14
Images: 13
on my 345 there is a small storage area in front of the Coach door and behind the battery tray. No slide out drawer
I think the one you mention is the one I have behind my coach door
It looks to be just right for a small tool box or maybe a battery ??? and close to the existing cables
Plastic Battery Tray Ganglin Batteries, Univolts, Converters & Inverters 3 07-24-2009 07:56 AM
Repair battery compartment latch? Anniedog Exterior Storage Compartments & Access Doors 3 12-05-2008 05:19 PM
Battery Holder tray ve3czn Batteries, Univolts, Converters & Inverters 2 10-27-2007 12:12 PM
Dish/Glass Tray from '65 Safari? Clapper82 1965 Safari 0 12-16-2006 08:10 PM
battery tray lido&linda 85/345 Mechanics Corner - Engines, Transmission & More... 3 09-16-2003 09:33 PM
