Old 04-01-2016, 09:21 AM   #15
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
Several years ago, I bought a used boat whose prior owner had relatively recently installed a Xantrex inverter. Within months, the Xantrex quit. I engaged a local marine electronics repairman to fix it. He told me that the Xantrex was fried & needed several circuit boards to make it work again, whose cost would be close to its original cost. In discussing alternatives, he said that in his experience, Xantrex inverters were unreliable & expensive to repair & that for only a few hundred dollars more, a new Magnum was available. I bought a Magnum (12 volt, 2800 watt). It's been on the boat, charging & inverting away, now for close to five years without any problem.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 04-10-2016, 08:10 PM   #16
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Thanks for the feedback gents. Looking at magnum inverter charger (2800watt).
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 04-26-2016, 06:16 PM   #17
Vycan's Avatar
Manhattan , Kansas
Took lewster's advice and redesigned my system went for:
1. Magnum MSH3012M
2. ME-BMK battery monitoring kit
3. ME-AGS-n Auto generator start
4. Magnum ME-RC-50 remote
5. The inverter will plug into the batteries with a 300a terminal fuse block for the inverter side of the house
6. 5x 100w allsolar flexible PV panels for 500w of charge, will afix using vulkem V116V white, the panels come with AWG12
7. Will connect 4x panels with a custom harness at AWG 8
8. Add in the fifth with a custom AWG 6 to controller
9. Windy nation Track Max 30L MPPT charge controller with remote and temp sensors through the refrigerator vent, for a maximum run of 8ft
10. Each panel will have a 8amp inline fuse
11. From thecharge controller I will run AWG6 to the coach batteries for 20ft where they will plug into a terminal fuse block
12. Terminal fuse will be a 30amp fuse
Can install on my own, but if the price is right, would like to save my time for other projects
-Vycan
Old 04-26-2016, 06:26 PM   #18
2014 25' FB Flying Cloud
Vancouver , British Columbia
Lew, I thought a Magnum Hybrid inverting from AGM batteries regulated the voltage allowing you to run the AC from the batteries if your bank is large enough. Is that wrong?
RubyDog is offline   Reply With Quote
Old 04-26-2016, 07:09 PM   #19
lewster's Avatar
Naples, FL , Hood River, OR
Not wrong…..RIGHT!! ……sort of.
The MSH=301`2M Hybrid doesn't really regulate the voltage as much as the amperage in a large use application like a roof A/C.
It will either operate the A/C solely from the batteries (you need a really big AGM bank for this, as they are subject to Peukert effect) or an appropriately sized lithium battery.
The hybrid inverter will also seamlessly apply required additional amperage for 'load assist' when attempting to operate high amperage appliances from a low amperage source; (think single 2000 watt generator starting and operating a roof A/C) where the small single generator could not otherwise handle that load.
Old 04-26-2016, 09:15 PM   #20
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Sounds like a nice setup! I have a Magnum ME 2012 and monitor to install, but I need to figure out where to mount it, and wiring on the AC side. You will need large gauge wire from the batteries to the inverter, so best to keep it close. The best setup I can figure is to use the one set of AC wires that exist in the passenger footwell that run the charger for the inverter input/ charge side, and run a second set or MC back to the distribution panel to run your AC loads. Install the batteries and inverter up front...would the weight be an issue? Still have some wiring to figure out.
SebasSF is offline   Reply With Quote
Old 04-26-2016, 09:20 PM   #21
SebasSF's Avatar
Hey Vycan, do you notice any difference driving with the extra weight up front?
Old 04-26-2016, 09:29 PM   #22
SebasSF's Avatar
And...can you please post a photo of your install?
Old 04-26-2016, 09:50 PM   #23
Vycan's Avatar
Manhattan , Kansas
I have not installed anything but the batteries yet. I will post a pic once I get her out of storage fro. Hail storms.
Old 04-26-2016, 10:45 PM   #24
SebasSF's Avatar
Thanks, it's the batteries I would like to see a photo of as they are tall...
Old 05-07-2016, 11:05 PM   #25
Vycan's Avatar
Manhattan , Kansas
Attached are the photos of the batteries in the front storage. They are not 'that' tall, but they are heavy!
ID:	262113   Click image for larger version
12v
Deep cycle battery not charging iamscuba2 Batteries, Univolts, Converters & Inverters 7 08-19-2011 03:17 AM
Deep cycle battery - unexplained power drain Al & Marilyn Batteries, Univolts, Converters & Inverters 3 09-17-2008 06:56 AM
Deep cycle battery switch jaiman Classic Motorhomes 3 07-23-2005 01:28 PM
Which Deep Cycle Battery? boltos Batteries, Univolts, Converters & Inverters 26 12-07-2004 05:57 PM
deep cycle battery replacement 26Argosy.ca Electrical - Systems, Generators, Batteries & Solar 6 01-02-2003 05:19 AM
