Old 04-16-2016, 10:48 AM   #1
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Battery solenoid replacement
Fitted one of these Surepower 200a solenoids to replace my temperamental stock solenoid on the back of the battery tray - seems to work well. Something occurred to me when I fitted it. Is that original solenoid grounded through its metal housing connecting to the rear of the battery compartment and then onwards to the main chassis woven ground wire? I think it is so if anyone is experiencing intermittent issues it might be that connection which is poor and causing charging problems. I fiddled around with the wires (be careful to disconnect batts) for years without actually figuring that out. The back of the battery tray was pretty grimy so looked like a very poor ground.
http://www.allbatterysalesandservice...fm/4,5736.html
Boom Sounds is offline   Reply With Quote
Old 04-17-2016, 04:49 AM   #2
bigbidule's Avatar
1981 28' Airstream 280
Lisle sur Tarn , France
I replaced my old diode battery separator with a 120A Cyrix relay ( alternator 140A / starter batt 100A, service batt 2 x 140A ) Very cheap and works great
bigbidule is offline   Reply With Quote
Battery tray solenoid replacement - is this best option? Boom Sounds Classic Motorhomes 8 07-12-2013 05:26 AM
Solenoid on Battery Tray - 1988 345 robersonwill Classic Motorhomes 6 06-15-2013 10:19 AM
Battery, Solenoid, Isolator Setup kennytheecat Electrical - Systems, Generators, Batteries & Solar 4 04-23-2009 08:45 PM
battery solenoid mystery Airstr345LE Batteries, Univolts, Converters & Inverters 8 03-22-2009 12:00 AM
Battery Solenoid ??? jisom12 Batteries, Univolts, Converters & Inverters 8 04-18-2008 02:45 PM
