Old 06-18-2011, 02:40 PM   #1
Sacramento , California
Battery fixed; now on to DC power
Thanks for the advice about the battery. Tightening the contacts and a jump start did the trick.
BTW, what is the ON/OFF switch in the battery compartment for? I've tried to find it in the manual.
I drove several miles today thinking it would charge the house batteries. I still have no power inside. Am I making the wrong assumptions?
I don't think I will ever winterize again... getting back up is turning into a nightmare (did I mention I learned about no differential on the axles when one side got stuck in the sand; that postponed my battery charging voyage by several hours and a winch!)
silverdream2 is offline   Reply With Quote
Old 06-18-2011, 03:34 PM   #2
1985 31' Excella
Fresno , Texas
The on/off switch is to prevent battery drain during extended periods of storage
Wsmith is offline   Reply With Quote
Old 06-19-2011, 06:47 AM   #3
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Keep observing and Learning.
In the end you will feel confident and in control
John H. is offline   Reply With Quote
Old 06-19-2011, 09:08 AM   #4
So should the On/Off switch be in the On position when using the RV? And could this be why I don't have any power inside?
Thanks.
Old 06-21-2011, 12:01 PM   #5
Images: 13
Thanks.
Yes, turn it ON
It should be Lit RED. if there is Power to the coach. or chassis
If it does not Light RED
start at the battery and follow the wires as HOT. Until there is NO Volts. Bingo, You found the Dead spot. Fix it and move on into the Coach.
John
electrical system
120 volt outlets from battery power? etobolski Electrical - Systems, Generators, Batteries & Solar 4 04-05-2011 02:15 PM
Only one battery charging heslinhotel Batteries, Univolts, Converters & Inverters 11 02-21-2011 08:49 PM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
