Old 06-10-2014, 05:48 PM   #1
Full-timer
nickglase's Avatar
1988 34.5' Airstream 345
new york , New York
battery drawer reconstruction - Stainless steel?
Hi All,
I just pulled my rusty battery box today. It was super rusty and getting dangerous.
My plan is to have a new box built out of stainless steel sheets. For structural members I'll either use fiberglass or aluminum.
Before I proceed, I thought I'd see if you all had any thoughts on using stainless steel for this application? I will need to rivet between stainless and aluminum.
Thanks very much,
Nick
Urban camping in San Francisco, Ca
1988 Airstream 345 Motorhome
1964 Vespa GS
1982 VW Qauntum, turbo diesel
1979 Triumph Spitfire 1500
nickglase is offline   Reply With Quote
Old 06-10-2014, 06:04 PM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Honestly,
Don't know how well stainless steel and aluminum will react being bonded to each other. Metals of different types tend to 'react', usually having a corrosive effect.
I'd definitely check with a metal working shop for their advise.
Any thoughts KeyAir?
Old 06-10-2014, 06:57 PM   #3
1974 Argosy 20
Kooskia , Idaho
Someone else did a post on reconstructing his slide out drawer battery box. You might want to search the motorhome forms to see if you can locate it.
Old 06-10-2014, 07:44 PM   #4
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
I'd consider laying one up with fiberglass.
Air Dog is offline   Reply With Quote
Old 06-10-2014, 07:59 PM   #5
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Between stainless and aluminium, aluminum loses (corrodes).
kscherzi is offline   Reply With Quote
Old 06-10-2014, 08:59 PM   #6
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Detailed reasons why not to do what you propose:
Galvanic corrosion - Wikipedia, the free encyclopedia
So if you live in the salt belt or near the sea, you will get salt residue, then the first rain will create an electrolyte slurry on the exterior pieces, the next thing you know, you now have current, and your steel is destroying your aluminum. The Navy's newest ship is having trouble due to steel and aluminum being mated together.
If you are in a dry climate and never plan to go to the salt belt, or the ocean your chances are reduced. personally I would not do it.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 06-10-2014, 09:44 PM   #7
reinergirl's Avatar
Hollis , New Hampshire
Why not rebuild it out of aluminum?
reinergirl is offline   Reply With Quote
Old 06-10-2014, 09:53 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Right now it is steel riveted to aluminum and it has lasted how long now?
If i was making the box i would reconstruct the box with 18 or 20 ga. sheet using my metal brake to add structure.
I would use steel or stainless steel and not worry about it again for the next twenty years or so.
Old 06-11-2014, 01:31 AM   #9
Full-timer
nickglase's Avatar
new york , New York
Just found a previous thread on this:
http://www.airforums.com/forums/f311...air-57991.html
1964 Vespa GS
Old 06-13-2014, 01:06 PM   #10
St Helens , Oregon
I am having the same issue with my battery box. Just had a buddy make me a bottom section out of stainless. I agree there is a definite possiblility of electrolosys but I am with you on the original contruction was with mild steel anyways. I'd say if it is a real possibility in your climate, isolate the parts where the ferris and non ferris metals join with battery terminal protectant or some kind of sealant. Make sure its a good coating cause you wouldn't want to trap moister inside. Just a thought....
tedly797 is offline   Reply With Quote
Old 06-13-2014, 01:25 PM   #11
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Ever notice all the stainless steel hatches,flaps, and doors Airstream sells at the factory store and online for their trailers as add ons?
Old 06-14-2014, 07:35 AM   #12
Vycan's Avatar
Manhattan , Kansas
Switz: Sarcasm does not translate well in text. It lacks the personal touch of non-verbal communication. To answer your question: Yes I have. They also come with gaskets to isolate them from each other.
Team,
You can do what you want, it's your moho. The fact remains it's not a matter of 'if' you will experience negative effects by combining the two, but "when." Assess your situation and assume the level of risk you desire.
Old 06-14-2014, 08:10 AM   #13
1988 Argosy 32
Lomita , California
fix as you wish, then prevent it a 2 time, Replace bat witl a AGM they are sealed.
I put a sheet of ruber under bat, ( i use lifeline bats )
Wolfe is offline   Reply With Quote
Old 06-14-2014, 08:12 AM   #14
switz's Avatar
2014 31' Classic
Images: 8
That is not a sarcastic comment. Every one of those stainless steel accessories is attached using either screws or pop rivets. Are the fasteners aluminum or stainless? They touch the stainless device and go into the aluminum skin or frame member. So the corrosion issue might move to the fasteners which are out of sight and out of mind until the device falls off.
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
Bathroom reconstruction Lothlorian General Interior Topics 7 07-02-2008 05:39 AM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
stainless steel wheel simulators Larry Brown General Motorhome Topics 11 11-26-2002 08:10 PM
