Old 04-14-2007, 04:50 PM   #1
1975 25' Tradewind
1986 34.5' Airstream 345
Lewiston , Idaho
battery compartment hinge replacement
Well spring has sprung in Idaho. I went out to do some maintenance on our 86 345 today. In our MH the battery compartment is on the passenger side in front of the entry door. This compartment holds 3 batteries and is very heavy. When I slid the compartment out today the left hinge decided to "give it up", then the right hinge followed suit and the whole compartment and 3 batteries fell to the ground.
I have now taken everything apart for replacement and repair. My question is does anyone have a recomendation on new hinges? Should I just buy new heavy duty accuride hinges or is there something better out there?
thank you
Patrick
flash is offline   Reply With Quote
Old 04-17-2007, 02:27 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
thank you
Patrick
Bumping this one up
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-25-2007, 06:03 PM   #3
Alliance , Ohio
Patrick, I was worried about the same thing happening to my battery tray. I found a similar slide to the original Accuride one but a little heavier. A pair of these are rated for 300 pounds load when used in a vibrating application like a motorhome. They have a 20 inch slide length which brings the tray out just like the original. There is some of "If a little bit is good, more is better" in me so I used two pair stacked vertically. The slides are available from McMaster-Carr Part Number 1102A66. McMaster-Carr is an industrial supply company but you can order off the web at McMaster-Carr using a credit card.
You will have to drill some new bolt holes. I made new brackets since I used two pair. Hope this helps,
Lance Mehes
mehes is offline   Reply With Quote
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
deep cycle battery replacement 26Argosy.ca Electrical - Systems, Generators, Batteries & Solar 6 01-02-2003 05:19 AM
Battery Slide Out niftypkg Electrical - Systems, Generators, Batteries & Solar 5 01-01-2003 03:41 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
62 Bambi Battery sbboyd Electrical - Systems, Generators, Batteries & Solar 5 09-20-2002 07:33 AM
