03-09-2012, 03:44 PM
2018 22' Sport
Airstream Coach - Other
ancramdale
, New York
batteries
i am completely at a loss...came home from long trip,parked ,turned everything of,as usual...every week i start the motor,or,i hook it up on my power line if i clean or run lights etc...and then suddenly..coach battery goes dead,can not event start generator,nor use the trick in the glove compartment...nothing.I try charging the coach battery,it will not charge..i go buy a new one...the motor starts right up,all is fine...the next day i check,its conpletly dead ans drained....what can possibly be the problem...read the trouble shooting ..nothing there i can figure out HELP
03-09-2012, 05:21 PM
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
What changes to the system have you made recently???
We are talking about you chassis battery here???????
Its better to use chassis and house to define each battery.
Have you got a compartment light on.
When I was searching on my Clipper recently I discovered the front compartment light was wired to the chassis circuit, and all the rest wired to the house circuit.
I presume this was a standard wire layout as most Airstream bodies were front engine gas, and a hood light would be needed there.
Only other option I can give you is to start testing each fused circuit with a test lamp to see what is drawing power.
Install good battery and ----
Pull fuse, insert short jumper and connect test ground to one side of fuse block and insert pointed end in the other. If it lights that circuit is drawing power.
Dave
03-09-2012, 07:50 PM
1984 31' Airstream310
Honokaa
, Hawaii
We had similar symptoms on our last trip. Cables and terminals at the batteries were good. On ours, the cable from the positive post of the chassis battery attaches to a solenoid on the back of the battery tray. The cable terminal at that end had broken and was creating havoc.
03-10-2012, 06:37 AM
1989 34.5' Airstream 345
Silverton
Our + cable from the chassis battery had a hole abraded in it from years of pulling the drawer in and out...other drainers I have found were the glove box light(door didn't always close) and the vanity light in the passenger side sunshade...also, the radio comes on after disconnecting then reconnecting the battery...
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
03-10-2012, 11:08 AM
2018 22' Sport
ancramdale
, New York
will get help with this one....checked glove comp,radio is off,i have the kind you can remove..vanity has been none functional..will check everything else you all suggested and keep you posted...thank you.
03-10-2012, 11:53 AM
Silverton
Probably should have said that the + CABLE from the battery to the solenoid behind the steps can get worn...you will have to crawl under to see/feel...uhm, I highly recommend disconnecting the cable from the battery...I didn't...SHOCKING!(& not much room to respond in...)
Michael & Tracy
1989 345 Motorhome
03-10-2012, 02:42 PM
2018 22' Sport
ancramdale
, New York
I have a feeling you are right about the steps wire.....will check that too.
At this point i have disconnected All 3 batteries...waiting for my friend Don to come over and help me figure this out with all your very helpful ideas to test out ....thank you
03-11-2012, 01:17 AM
1982 28' Airstream 280
Port Angeles
If you have a new battery going dead overnight you have significant power draw somewhere. When you connect the battery cables you should see a spark. If not check the battery to make sure it has a good charge. If the battery has a good charge and no sparks during connection you probably have a loose connection somewhere. The solenoid behind the step and also where the plus cable connects to the starter. All power to the dash and ignition goes through this connection. Also check where the negative battery cables connect to the frame, easy to overlook.
Good luck, Dan
03-11-2012, 08:26 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
My Airstream motorhome is an Interstate class B, but the problem I had with the house batteries discharging might be similar to the problem in your motorhome. On mine, there is a switch next to the propane fill valve, that controls the propane feed from the built-in tank to the various appliances by means of an electromagnetic solenoid. Power on, electromagnet holds valve open; power off, spring forces valve closed.
This one switch— or rather the solenoid controlled by the switch— all by itself, draws about 2 amps 'round the clock when it's in the "on" position. It needs to; for safety reasons, the spring holding the valve closed is a strong one.
Anyway, the point is, I was draining about 48 amp-hours from my house batteries every day just because of this one easily-overlooked switch, and it didn't take long at all before the batteries were depleted to the point where I couldn't even start the generator to recharge them. I had to pull the batteries (a chore in itself) and recharge them on a bench. Believe me, ever since, I've never had a problem remembering to switch off the propane, and I've not had another problem with dead batteries.
03-11-2012, 09:40 PM
Foothill Ranch
Had this also.
Mine was a Shower fan that was seized, and because I did not hear it spinning, assumed it was off.
03-12-2012, 05:11 AM
From All Over
Not necessarily. If you connect positive first, then negative, and all power users (lights, etc.) are switched off, there should be no current draw during connection, and so no spark. If you see a spark, that means something was switched on while you were connecting the battery.
03-12-2012, 08:16 AM
1989 25' Excella
Hobe Sound
I would assume that your 290 is much the same with coach and chassis battery connections as is my 89 345. The two main electrical cut off switches for storage (to the left of the door on the wall) control selinoids that disconnect the batteries when stored. I have a slow drain in the chassis which I haven't found yet, so when camping, cut off the chassis battery until ready to leave. Note the orig setup will not charge the chassis battery when pluged into shore power. All batteries will charge with engine running or with gen running or both running. I recently installed DC volt digital read outs to both the bat sets and 120 AC visable in the coach. Now can watch the drain or the voltage available, charging or not ect at all times. Hope to find the drain soon. I'm told to find an isolater leak is a long problematic search!
03-12-2012, 08:52 AM
From All Over
The process is complicated by the fact that both chassis and house batteries have items that draw (supposedly small) amounts of power even when the batteries are disconnected at the switch, because those circuits bypass the disconnect switch. On my Airstream, the Kenwood head unit still draws a small amount of power from the chassis battery when the engine is switched off and the chassis battery disconnected; so does the aftermarket alarm system I had installed. And I'm sure there are other things I haven't tracked down. For the house batteries, it's the propane solenoid, the retractable step lock, and the battery monitor in the solar panel circuit. Again there may be others I haven't tracked down.
03-13-2012, 12:15 AM
Port Angeles
That is the point, if you get a spark something is on or faulty and drawing down the battery. If no spark then look for bad connections or possibly a faulty battery. There are many possibilities but I like to try the simple checks first to try to get a direction to look before starting the more difficult work.
Maybe I could have worded it better but a new battery going dead overnight has a large drain and should show a significant spark. Radios, digital clocks, alarms and such should take many days to run a good battery down. Again it's just a starting point to figure out where to look first.
Cheers, Dan
03-13-2012, 08:26 AM
1977 28' Argosy 28
Bullhead City
I may be way off here but you might check your alternator. I know when they go bad they can still charge but will drain your batteries overnight.
Jo
Gypsy Jo 1977 Argosy 28' Motor Home
03-13-2012, 08:38 AM
2018 22' Sport
ancramdale
, New York
My friend Don and Brady are coming today or tomorrow to start our detective work....going with all your input,ideas,personal experience,comparisons..leading to solutions...i have a feeling its going to take a while...the 3 batteries are fully charged and ready to be re connected....will check your spark theory too...so lucky this did not happen on the road.As soon as we start attempting to trace the problem,i will report to you step by step and your continued input for which i thank you is very much , is valuable and greatly appreciated.Martine V
03-13-2012, 11:32 AM
1991 35' Airstream 350
Laurel
, Maryland
I use 3 of these
This will cut the power completely. You will need to reset the radio memory and anything else that needs power.
03-15-2012, 01:17 PM
2018 22' Sport
ancramdale
, New York
battery
it is not the batteries!!!!!!we put on 3 battery disconnect...then connected everything,all 3 are fully charged....and nothing.....could not get anything going ,just a tic tic tic noise...so...i quess its either the alternator or the starter or??????have to call sam's club road service to send someone over to check it out....its beyond me...thanks for all your input,i am glad i have those disconnects on now for the future...M
03-15-2012, 01:33 PM
From All Over
Originally Posted by la nomade
could not get anything going, just a tic tic tic noise
tick, tick, tick is the starter solenoid. It's attached to the side of the starter, and it is basically an electromagnet that causes the gear on the starter to engage the gear on the flywheel. It usually happens when you don't have enough power to activate the solenoid, but can also be caused by a loose wire or a defective solenoid.
03-15-2012, 02:11 PM
Port Angeles
Check the connections on both ends of all the battery cables and the cables themselves.
