Old 03-27-2012, 12:39 PM   #1
1995 36' Classic 36
Ludington , Michigan
Bathroom Floor
This picture is from Fred's archives. I really like the look and want to do something similar. I talked to the owner and he mentioned a 3M product that was used to glue the tile down. I searched the forums and everyone seems to recomend against ceramic tile in a motorhome. I know some units have ceramic tile floors from the factory. Anyone know how I might install one without cracking or delamination problems?
Thanks, Dave...
Kota is online now   Reply With Quote
Old 03-27-2012, 12:49 PM   #2
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Weight would be the biggest issue, as well as the issue of flexing of the underlying floor when you're on the road, and cracking of the grout or tiles popping up. I don't think it's worthwhile to try and stiffen the floor- you're transferring flex-loads elsewhere in the frame of the vehicle- BUT, it might work to use something other than cementitious grout between the tiles, like the grout-colored and textured caulk that grout manufacturers sell for tile joints that are subject to minor movement. I always beef up floor structures in residential projects when tile or stone will be installed, to minimize flex and movement.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 03-27-2012, 06:28 PM   #3
1995 36' Classic 36
I don't think 25 lbs will be too big of an issue on a 15,000 lb coach. I did get a response from a guy that installs factory ceramic tile floors on high end coaches. He recomended pronducts from.
http://www.laticrete.com/Portals/0/d...ts/lds6330.pdf
I also found a product from 3M which I believe was used in the picture above.
I'll pull out the vinyl that the PO did a pretty amateurish job of installing and see what the floor looks like.
Anyone know if there are access ports to get at the grey water level sensors? My poo tank always shows about 25%.
Old 03-27-2012, 09:25 PM   #4
Globie64's Avatar
Images: 18
25 pounds in a 15k rig isn't much. I was thinking it was more like 200, and it's located between frame members and on plywood that is more flexible than the tile. I'm sure with the right materials you can make it work.
Leaks and Floor Rot in '91 34' Limited Steve Bryant Repairing/Replacing Floor &/or Frame 393 01-16-2016 12:38 PM
Our Turn for Floor Rot - Do We go to Ohio? Frank&Mike Repairing/Replacing Floor &/or Frame 50 05-23-2012 06:18 AM
1976 31ft rear bath sovereign floor rot Treyladut Repairing/Replacing Floor &/or Frame 10 03-28-2012 03:30 PM
Floor plan for 1974 overlander freerider General Interior Topics 1 03-26-2012 08:55 AM
Bambi floor plan with rear twin ? Aktundra 1961 - 1963 Bambi 0 03-25-2012 02:13 AM
