Old 08-07-2017, 06:32 PM   #1
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
backup camera replacement
So, I have the diesel engine running (1996 Cummins) and the Allison transmission (2008 Chevy) working. Now I need to look at replacing the none-functional backup camera. What to use? Can I use the wiring for a new system? What about one with blind spot cameras? Don't want a wireless system because I really what the blind spot cameras.
Remember this is a 1986 34.5 motor home.
choctawmel is offline   Reply With Quote
Old 08-07-2017, 07:12 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Many of the wireless systems will support many cameras. Is that 4, or 12 or something in-between? It depends on which one you get. The existing wires will give you power and that's the biggest PIA in getting this sort of thing hooked up.
As to which one. Find a place you can actually *see* how (bad) the cameras are. Finding something that has the dynamic range and clarity to be useful is not as easy as it should be.
Old 08-07-2017, 07:50 PM   #3
Alliance , Ohio
I used the original wiring to get power to and video signal back to the dash. I found a camera I could fit inside the original housing. It gives a good color picture in daylight and adequate vision in black and white in the dark. It had the ability to reverse the image so left and right would appear as in a rear view mirror. Most displays have such ability now a days. Short answer, I stuck with a wired camera and used the original wiring.
mehes is offline   Reply With Quote
Old 08-07-2017, 07:57 PM   #4
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I second Lance's work....did the same thing on the 325LE and the first 370LE.....that'll get guys going......Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 08-09-2017, 02:52 PM   #5
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Years ago the 12-24VDC power supply smoked and I bought a 110VAC-24VDC supply then used a 12VDC to 110VAC inverter.
I really hate to peel the dash open to get to all that. Every time I do I knock something off the back of the dash board. That hot glue they used to mount all the light and switched just don't hold up after 31 years.
Guess I'll take a car trip to Camping World and see what they.
Old 08-09-2017, 03:25 PM   #6
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Want system did you use?
Old 08-11-2017, 06:52 AM   #7
1991 35' Airstream 350
Mentor , Ohio
Backup Camera
This is an interesting topic for me. I have a wireless system in the 350LE, which works intermittently. I have been trying to get more information on the Pro Vue 360 ASL system from the manufacturer - we have it in another car and it is really nice. I think it would be awesome in the 350LE.
Backup cameras are nice, but does anyone have a surround view system on their moho?
Dave
dspaw is offline   Reply With Quote
Old 08-12-2017, 12:47 PM   #8
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
The Pro Vue 360 ASL system looks good, but looks like you'd have to travel by land and by sea and by land again to get one.
It's raining outside (thank God!) so I decided to tear into the backup camera. Not as easy as I thought.The lens cover came right off and two screws hode the camera into a 15 pin connector. Had to take it completely apart to the the 15 connector plug and wire loose. The builder did have enough slack wire to work with.
Will need the right video connector to install on the cable to match what ever is on the new system and then I'm guessing I only need two of the 12 other wires to make it work.
Next step is into the dash. And that is a nightmare I don't look forward to.
Inside the box.
W/O the camera
Back of the camera
All back together with workable amount of extra wire
I contacted the people I bought the 'complete' T-1000 tranny and all the electronics to make it work. Now that I need the backup nights to work I call they as to where that wire is? OH! Now I need a $90 neutral safety switch and a $150 pigtail from them to have backup lights and a neutral switch.
There 'complete kit' keeps needing more and more!
Old 08-14-2017, 07:18 AM   #9
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Well I did it. I opened the dash and looked at all that mess of wiring. Didn't remember how I did the power supply setup years ago. Unplugged the monitor then the one plug on the power supply. It's the 12vdc, ground and backup lights (I think) Once again the builders left enough wire to work with for a new system.
You can see the power/switch box way down in all that mess.
Scrap video system. Anyone need some spare parts before this pile goes into the dumpster.
Now it's shopping time. What to get?...... What to get????
Old 08-16-2017, 11:04 AM   #10
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
This is the system I'm thinking will work. Can get splice connectors to use old wiring.
https://www.rearviewsafety.com/safet...d-back-up.html
Old 08-17-2017, 08:17 PM   #11
Mentor , Ohio
That looks like a nice system. Where would you mount the side view cameras?
Old 08-20-2017, 02:18 PM   #12
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
I thinking on or under the mirrors. Getting the cable to them will be a change. Anyone know how to get the inside panels off w/o damage?
Another place would be just behind the headlights. Cabling would be easier.
This means more wire behind the dash. Will need to connect to the turn signals.
Got the neutral safety switch installed. Not wired, but installed.
Going to be gone for a couple weeks, so will order next month.
Old 08-26-2017, 03:47 PM   #13
Mentor , Ohio
Watching with interest. This in my future.
Old 09-06-2017, 02:53 PM   #14
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Just ordered the stuff from post #10 with splice connector to use the old cable.
which wire is the backup wire- rearexterior backup, stop turn light waninae39 Tow Vehicles 38 07-03-2017 07:09 AM
Backup Camera Replacement johndes General Motorhome Topics 1 06-08-2014 02:17 PM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 05:37 PM
Replacement backup camera system humoso Land Yacht/Legacy Motorhomes 2 05-01-2009 12:11 PM
Homemade backup camera 83Excella Airstream Trailer Forums 28 08-17-2005 01:31 PM
