04-12-2012, 09:59 AM
Alumnati
1986 34.5' Airstream 345
Fredericksburg
Awning rafter mount issue
I just replaced the patio awning on our 1987 345. The old awning was broken in several places, the fabric was shot and several of the original mounting points were damaged. I assume that high winds had torn out some of the mounts and larger screws had been put in. I minimized the damage to the skin as best I could, installing the new hardware, using some over-sized screws where needed. All worked out well except for the rear rafter mount, the one with the small threaded wheel to lock the awning in place for travel. It had been torn up so badly that all the screw holes were enlarged to the point that the new screws would just barely hold and after a few light breezes the screws began to pull out. I've seen on other trailers that this has been repaired by riveting on a piece of aluminum over the damaged area and re-mounting the hardware on the new piece.
The problem is this; the original mount went through the skin and into a rib, giving a nice hunk of solid metal for the screws to bight into. Zip Dee says to mount this particular bracket with screws, not rivets, but the inner rib is so damaged that there is nothing there for the screws to take hold of, leaving just the new patch as the attach point. I just don't think that is enough material to provide the strength needed. I am leery of rivnuts or nutserts, a threaded insert much like a pop rivet. Can anyone tell me the correct way to do this repair?
04-12-2012, 10:34 AM
Corona
The only reasonable fix, is to add a plate about 1/8 inch in thickness to the exterior, and then mount the awning bracket.
Make sure you attach the plate to the main bow as well as the sheet metal.
Also make sure it's proper sealed.
04-13-2012, 08:07 PM
1991 35' Airstream 350
Columbia
I used Rivnuts to fix my problems with the top mounting screws striped out.
Used in aircraft and many other places higher strength is needed.
Custom Rivnuts Fasteners and Plusnuts - Rivnut Blind Fasteners at Cardinal Components
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
04-13-2012, 08:37 PM
Columbia
Here are the ones that I used. Just about a flush mount. Over 5 years, much wind and rain, no problem!
AIR Member 12654
1991 350LE "Zephyr"
04-14-2012, 10:58 AM
1984 31' Airstream310
on the road
, CA and OR this summer!
i had the exact problem and repaired just as Andy said. just be sure to use plenty of Vulkem in the inside and arround new bolts, and rib. be sure to check if there are minor dents or broken seals between the surrounding skin layers....i had a tiny leak that now needs partial floor replacement because of (invisible) damage caused by that awning.
and you can only get to it by removing interior panels...yea!
i'll post a pic of the plate we added to reinforce later.
1984 310 Limited Motorhome
my AS Moho blog for the love of all vehicles round and shiny
04-14-2012, 02:22 PM
1989 34.5' Airstream 345
Silverton
Wondering...if you have to put in a plate, can't you reinforce the rib while you have the skin off?
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
04-14-2012, 08:08 PM
Corona
The plate mentioned, would be installed on the outside of the sheet metal.
No need to remove any metal.
