Old 01-09-2005, 02:49 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Unhappy Auxillary heater?
Hi all,
I have a 1984 310 Limited MH. I am having some interior work done, mainly a remodel of the bedroom and bathroom, but also new flooring throughout. Carpet in the bedroom and 'Cockpit', pergo like Wilsonart floating flooring in the bedroom, kitchen, dining room, den, and parlor :<).
The fellow doing the work called me last night to tell me that the floor was soaked under the couch and that the sub floor was rotted. Bummer. He said he thought the aux heater under the couch might be leaking. He then said that this heater had hoses going to the water heater?!
Can anyone explain how this thing is supposed to work?
I had assumed that it worked off of engine coolant and that since I didn't lose coolant, it wasn't leaking?
guy99 is offline   Reply With Quote
Old 01-09-2005, 03:29 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The coolant hoses run form the engine to the aux heater, then to the water heater and back to the engine. The floor could be soaked form a slow leak that has been happening for a while. If you replace the hoses have the heat exchanger for the aux heater tested before you reinstall it they tend to leak after 10 years if the coach did not have regular cooling system maintenance.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 01-09-2005, 06:48 PM   #3
guy99's Avatar
Images: 16
Thanks for your response. What is the purpose of connecting to the water heater?
Old 01-09-2005, 06:57 PM   #4
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The connection to the water heater is so that you have hot water if you need it on the road, without lighting the heater. It is also always there.
Brett G
Old 01-09-2005, 06:58 PM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Reason for Water Heater/Engine Tie-in - Safety Feature
Hot water is available while you are on the road without having to run the burner in the water heater (see other threads on the pro's and con's of running a burner while actually on the road).
The engine water will actually heat the water in the heater ABOVE the shut off point of the burner - what this means is that sometimes you have to wait a bit before the igniter will light the main burner (if you have an electronic ignition on the water heater).
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 01-09-2005, 08:16 PM   #6
LOST , Hawaii
Can he still run the engine? If so run it until it is warmed up while running the auxillary heater, you should be able to smell antifreeze if that is where the leak is coming from.
Just my 2¢. The motoraid water heater and auxillary heater are pretty common for high end Class A motor homes. I am surprised anyone who would take on a job this large had not seen this; keep close contact with your motor home as the work progresses.
John
74Argosy24MH is offline   Reply With Quote
Old 01-09-2005, 10:25 PM   #7
guy99's Avatar
Images: 16
This guy is in Junction City Oregon, close to Monaco, Marathon, etc. He does lots of work on big diesel pushers. He seems to know what he is doing in general but has no Airstream specific knowledge. I asked the local (Eugene) Airstream dealer about doing this work, but he didn't bother to give me a proposal. So I took the plunge. We'll see how it all turns out. Remember the original idea was to do an internal remodel. The problem has been concealed floor damage and roof AC without seals. By the way, this summer I took the MH to the factory in Jackson Center and one of the items I asked them to check was weather seal relative to the AC's. So if I can't trust the factory service center to notice that my AC's didn't have proper seals I guess I just have to take my chances. I asked the Service Center about this remodel but they seemed totally uninterested. I also e-mailed Andy of Inland RV twice to ask whether this was the kind of job his shop does, he didn't reply to either message.
Old 01-10-2005, 07:31 PM   #8
guy99's Avatar
Images: 16
While we're on the subject
of the auxillary heater, can you tell me what the high/low switch on the dash do? Do they control water flow or merely a fan?
Old 01-10-2005, 08:38 PM   #9
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Fan only. There is a pull knob for temprature control.
Brett G
Old 01-11-2005, 09:52 AM   #10
guy99's Avatar
Images: 16
Where is this pull know located/what does it look like. I've put over 10,000 mile on my MH and didn't think there was a pull knob I haven't noticed
Old 01-11-2005, 10:23 AM   #11
87MH's Avatar
1978 31' Sovereign
Images: 292
Pull Out Knob
Pull Out Knob is adjacent to the (aux) heater, usually mounted just forward of the heater. If you are close by the coach, lift the sofa (if that is where the aux heater is - I have also seen them under one of the Dinette seats), and the actual control valve is mounted in the hose just to the rear of the heater.
You can access the control knob (adjust the amount of coolant going through the aux heater) by opening the sofa or dinette "storage bin" closest to the heater. If the valve has not been operated in a few years anticipate a stuck valve - the valve is identical to those found in the hood area of most autos controlling the amount of flow to the automobile heater.
Take the old one to a parts store and you should be able to match it.
The "Control Knob" is attached to a simple push/pull solid wire within a coiled wire (a la' a lawn mower throttle control) - also easily duplicated with standard hardware.
Dennis
WBCCI # 1113
AirForums #1737
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 02:35 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
