Old 12-25-2015, 01:22 PM   #1
Aluminated
1987 29' Airstream 290
El Cajon , California
Images: 14
Auxiliary Heat
Does anyone know what the rocker switch on the dash that says "Auxiliary Heat' do? I live in So Cal and don't have a need for much heat, but the buyer of my 87 290 would like to know because he's on his way to Colorado and he will need as much heat as he can get!
ericjan2 is offline   Reply With Quote
Old 12-25-2015, 03:38 PM   #2
1986 34.5' Airstream 345
Wake Forest , North Carolina
It controls the aux heater under my couch on my 86 345
Dick
ww4nc is offline   Reply With Quote
Old 12-26-2015, 01:07 PM   #3
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Your Colorado buyer needs to be aware that with the Aux Heat system, he has at least 20 ft (maybe more depending on Heater location) of heater hose running from engine to Aux Heater location.
If your Airstream has been in warmer climes, good bet Aux Heater hoses have been blocked off.
Just a thought, Derek
Old 12-27-2015, 05:16 PM   #4
Aluminated
Images: 14
I'm wondering if there is one on a 290??? All I have under the couch is the water heater and the door bell! Although AS did use standard items on all motor coaches, such as my selector switch has a blender selection and an oven selection of which I have neither. Also has a blender selection! Perhaps the dash is universal and although I have the rocker switch on the dash, I don't really have Aux heat! My dash also has a glo plug light but it's gas! Hummmmmm
Old 12-27-2015, 07:21 PM   #5
1974 Argosy 20
Kooskia , Idaho
My '83 310 had a "water in the fuel" and a glow plug light even though it was 454 gas engine powered. The water in the fuel light would come on randomly, and then go off. I never did figure it out.
The auxiliary heat on my 310 was under the front couch and the pipes which supplied the engine coolant to it also did the engine pre heat of the hot water tank, which was next to the heater. Pretty fancy for 32 years ago. The dash switch was labeled aux heat on mine. But a friend's '81 280 with the diesel engine did not have the aux heater, or the hot water pre heat feature. Also no switch for the heater.
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
