Old 03-04-2018, 10:23 AM   #1
1987 32.5' Airstream 325
Windsor , Ontario
Automatic step magnetic sensor placement
My magnetic sensor for my Kwikee auto-step bracket has broken.
It is located on the latch side about 1/3rd of the way up from the bottom.
I recon this location is not optimal there is easy access for it to be hit as you enter the RV.
Question?: any recommendations on a different mounting location out of harms way and still function properly?
Thanks in advance for replies.
Chris
realpank is offline   Reply With Quote
Old 03-05-2018, 02:59 PM   #2
chriscraw's Avatar
1991 35' Airstream 350
Step switch sensor
Here are a couple of pics of my step switch install which works well despite a badly fitting screen door. Hope this helps.
ID:	305717   Click image for larger version
chriscraw is offline   Reply With Quote
Old 03-06-2018, 09:33 PM   #3
Windsor , Ontario
Thanks Chris
What I was hoping to see.
I'm hopefull that being more aware it might not get whacked next time in the same location
New MicroPulse Sensor and re-cal... post mortem on old sensor RFP General Repair Forum 10 10-25-2017 08:29 PM
Interstate Step: Magnetic Switch Fix ArcherTC Sprinter and B-van Forum 3 09-13-2017 02:24 PM
Magnetic Hitch Locator Tamara Hitches, Couplers & Balls 7 07-18-2004 08:58 AM
automatic step won't go up deano Airstream Motorhome Forums 0 08-23-2003 08:36 AM
Magnetic Brake Controller MattyBoy Brakes & Brake Controllers 3 01-04-2003 02:29 PM
