Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 12-01-2014, 07:48 AM   #1
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
Auto Reset Automotive Circuit Breakers - 12 volt
There are 3 of these circuit breakers in the front of my 91 350 LE right beside the battery isolator. Does anyone know what amperage they should be? I need to replace one and I figure I will just replace all three. I know they are 12V but I'm not sure what amp to order. I think they may be 30 amp but I am not sure. There are no markings on them at all. Thanks for your help. Steve
t7389sg is offline   Reply With Quote
Old 12-01-2014, 09:20 AM   #2
1974 Argosy 20
Kooskia , Idaho
Are the wires fairly large which go to the CB's? Like #10? If so, 30 amp may be the correct size. If the wires are smaller, like #14 or so, then probably 15 or 20 amp would be what they are. My '83 310 didn't have any self resetting CB's in that area, so this is only a guess on my part.
Do you know what the CB's protect? That also would give you a clue as to the proper size. If they are near the isolator, and connected to it in any way, they could be charge lines to the batteries, and would be 30+ amps I would think.
Old 12-01-2014, 10:41 AM   #3
t7389sg's Avatar
Laurel , Maryland
the circuit breaker that has failed protects the air compressor for the rear air bags and that wire is fairly large. I would think a 10 gauge. the 2 other breakers are 14 or 18 I would guess. I will look through the large owner manual for this rig and see if they mention the amperage requirement for these. I may even have the wire diagrams for this coach somewhere. Thank you for your responce
Old 12-01-2014, 10:46 AM   #4
dznf0g's Avatar
Oswego , Illinois
All circuit breakers I have seen have, somewhere on them, a stamping or inked spec rating. Usually it is stamped in the metal housing or printed on the bottom (plastic) "board". It will probably require removal to read.
-Rich-
Old 12-01-2014, 02:18 PM   #5
t7389sg's Avatar
Laurel , Maryland
I will check again for some markings. These are plastic housing CB and are a little crusty from age. Thank you for weighing in on this. Steve
Old 12-01-2014, 05:54 PM   #6
wxbuoy's Avatar
Wildwood , Florida
Send a message via Skype™ to wxbuoy
Steve,
If you can wait till tomorrow afternoon when it is light I will be happy to go out and see if I can see if mine have any markings on them.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 12-02-2014, 08:57 AM   #7
t7389sg's Avatar
Laurel , Maryland
I looked again at the CB I removed and the only markings on it are AUX and BAT molded in to the top next to the 2 terminals.
Old 12-02-2014, 09:38 AM   #8
wxbuoy's Avatar
Wildwood , Florida
Can you attach a picture so I know what exactly I am looking for in the limited daylight when I get home
Dave and Felicia
Old 12-02-2014, 01:11 PM   #9
t7389sg's Avatar
Laurel , Maryland
i hope this worked
Old 12-02-2014, 02:16 PM   #10
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
I'm seeing what looks like undercoating on and around the breakers - are they underneath the vehicle? If so, that's a stoopid place to install them; no wonder one has failed.
These thermal resetting breakers are notoriously inaccurate, and these are lookin' pretty bad, with lots of rust on the connectors. They're cheap - replace 'em all, and clean up all the connections, and spray the finished connections with insulating varnish to keep the weather out.
Amperage ratings are probably on the bottoms, so removal of the failed one will be necessary. Be sure to disconnect the battery's ground wire before doing the work.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 12-02-2014, 02:26 PM   #11
t7389sg's Avatar
Laurel , Maryland
These are located under the front access panel to the engine to the right beside the isolator. I think they are covered in road grime as it wipes right off. Yes the wires are rusty and corroded and maybe a little cooked. My plan is to replace all of them and remake the jumpers and clean everything up. I just need to order the correct CB. They are not expensive but I think I do need to get the amp rating correct. I post here to find out if anyone here has done this before and to find out what did they buy to fix this. There are not any markings on these CB's other than Batt and Aux.
Old 12-02-2014, 04:16 PM   #12
wxbuoy's Avatar
Wildwood , Florida
Steve
All mine have 30A on them. So I guess they are just there for power distribution to the sub fuse panelsClick image for larger version
Name:	ImageUploadedByAirstream Forums1417562132.030738.jpg
Dave and Felicia
Old 12-02-2014, 08:32 PM   #13
t7389sg's Avatar
Laurel , Maryland
Wow your wires are a little rusty like mine. I think you're rIght about these feeding the fuse box except the one in the middle. I know that one goes direct to the rear air compressor. When your ready to renew yours I will have the 411 to help you. Thanks again, Dave. Oh and you listing Good Sam as your tow vehicle made me laugh.
Old 12-02-2014, 09:02 PM   #14
1974 Argosy 20
Kooskia , Idaho
On those type of self resetting CB's I have found the rating stenciled on the bottom of the unit, so they may have to be removed to read that (if it is there).
Those terminals are mostly in bad condition, and you definitely should replace them when you do the job. The one short jumper even looks to have overheated with the yellow insulating material deformed.
Old 12-03-2014, 04:00 AM   #15
wxbuoy's Avatar
Wildwood , Florida
Steve
I plan on replacing them and cleaning up the connectors this winter. I also going to do the battery isolator as well. Any info on source of supply would be great!
Dave and Felicia
Old 12-03-2014, 10:48 PM   #16
Slowpoke
Gnorts's Avatar
Portland , Oregon
30 amp. In-Line Circuit Breaker - Perpendicular Mount Bracket Pollak Accessories and Parts 38630
Old 12-04-2014, 02:49 AM   #17
wxbuoy's Avatar
Wildwood , Florida
Thanks!
Dave and Felicia
Old 12-04-2014, 08:06 AM   #18
t7389sg's Avatar
Laurel , Maryland
This is what I ordered from www.delcity.net
I needed 2 with one kind of mounting bracket and 1 with a different type of bracket and I ordered some type of rubber cover for each as well. I will report back how well they fit.
1 71130 30 Amp Auto Reset Plastic Circuit Breaker$2.14 $2.14
2 72255 30 Amp Auto Reset Plastic Circuit Breaker$2.14 $4.28
3 907201 Stud Mount Circuit Breaker Insulator, Red$0.61800 $1.85
1 DC2015 2015 Del City Catalog (1 MIN) $0.00 $0.00
Shipping: $7.99
Total: $16.26
Old 12-04-2014, 09:52 AM   #19
wxbuoy's Avatar
Wildwood , Florida
Great, will wait for your report before proceeding.
I have to locate a compatible isolator in the mean time. Not to mention a whole lotta stuff to do on the inside!
Dave and Felicia
Old 12-04-2014, 10:46 AM   #20
Wise Elder
Jammer's Avatar
2010 30' Classic
I've had good results dealing with delcity.
12 volt
Propane auto shut off reset mayco LP Gas, Piping, Tanks & Regulators 2 09-30-2014 12:17 PM
Can't reset circuit breaker evamcmahan Electrical - Systems, Generators, Batteries & Solar 2 03-21-2010 08:54 AM
Electrical Newbie with circuit breaker that won't reset...help please! Kerina Electrical - Systems, Generators, Batteries & Solar 13 05-04-2008 09:18 AM
Circuit breakers,94 33ft Motor Yacht rayschell Batteries, Univolts, Converters & Inverters 4 07-10-2005 11:35 AM
Electric Heaters Tripping Circuit Breakers streamlean General Motorhome Topics 11 01-20-2004 09:29 PM
