Old 11-23-2008, 09:15 PM   #1
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Auto-lock Feature
Not sure what to do at this point but I would like to disable the "Auto-Lock" feature my moho seems to have. I was able to learn the code for the elecrtonic keypad that unlocks the door, but 2 times now I have gone out to out MOHO and discovered the door deadbolted shut. I can now enter the code to unlock the door but am confused as to why it is locking itself in the first place. Any Ideas????
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 11-24-2008, 08:36 AM   #2
1989 34.5' Airstream 345
Silverton , Colorado
Buttercup,
Do you have a manual lock from the inside? We don't have the keypad, just a Schlage deadbolt, but occasionally the manual handle from the inside drops down(gravitationally) enough to lock it...we have resorted to using rubber bands to hold the handle up when we are stationary for awhile...I would try to fix what appears to be a simple mechanism, but am afraid that my talents would make it worse
We also now have a spare door key hidden in...well, hidden...climbing in a window is not an easy project, even when there is a window left unlatched.
mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 11-24-2008, 09:45 AM   #3
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
We do have an exterior touch-keypad thing and I was able to locate the code from the controlbox located under the gally sink. I read that the keypad will only unlock the door. It will not lock it.
I do not think it is dropping gravitationally because it is a little stiff to mov in the first place. It seems like something, perhaps the resident mouse we seem to have, is causing the lock to activate. The manual does not have any information about it that I could find. It just locks...
Anyone used auto levelers? jameseerwin Jacks, Stabilizers, Lifting and Leveling 4 12-12-2007 04:58 AM
Auto-on furnace Dan S All Argosy Trailers 7 03-25-2007 08:56 PM
Auto Park jim8860 Mechanics Corner - Engines, Transmission & More... 9 07-13-2005 08:07 PM
Auto trans help Nick Danger Mechanics Corner - Engines, Transmission & More... 13 09-20-2004 03:59 PM
Auto Park jim8860 General Motorhome Topics 5 01-22-2004 05:28 AM
