Old 12-03-2011, 04:23 PM   #15
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Originally Posted by Silver Goose View Post
I have one of these wands and it manages to get past the copper line and into the tank. Most RV supply stores have them and they are available online. Always amazed how much sediment comes out every year when I drain and flush it with this. The stream is pretty strong and by angling it down and around is stirs up the stuff off the bottom and most finds it way out.
So, a male x male threaded bush is all you need? Is that pipe thread x hose thread? Does the drain spigot bend out of the way or does it have to be installed every time you drain?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 12-03-2011, 06:41 PM   #16
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
This one attaches to the end of a garden hose, the plastic wand section is inserted into the open WH drain. The tip of the wand makes nearly a 90 bend allowing you to detect the stream down and around in the tank. The water carrying the sediment flows out the open drain while you work the wand around. The wand has some flex so it can be inserted past the gas line into the drain.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Adding Electric Heater to Atwood ElliotA Water Heaters, Filters & Pumps 4 05-19-2013 01:53 AM
New atwood gas/absorption fridge lewster Commercial Listings 17 02-25-2012 07:59 AM
Atwood water heater burnt wire richinny Water Heaters, Filters & Pumps 5 06-21-2011 07:27 AM
new atwood 7900-11 furnace help hgut Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-10-2011 05:09 PM
Sealing around atwood water heater Hueytownalss Water Heaters, Filters & Pumps 1 06-02-2011 10:07 AM
