Old 02-17-2011, 08:22 AM   #43
AirRowan's Avatar
1986 34.5' Airstream 345
Key West , Florida
The fuse is on the Brown jumper in the glove box fuse box. If you look at the AS manual it shows were on the grid (brown) the air compressor is (25amp?). I think you have the oil pres switch like I do so the compressor will not come on till the motor is fully running and making power.
I jumped mine off the water pump till I change the 454 out. In this post thy talk about the oil switch some were on the left side of the motor I think.
The PO used a stainless steel fire extinguisher that he drilled and taped for the air tank.
Josh
AirRowan is offline   Reply With Quote
Old 02-17-2011, 08:59 AM   #44
Kenneth
1987_345's Avatar
1987 34.5' Airstream 345
Waxahachie , Texas
Wiring Diagram
Ok guys. Please find attached the drawing out of my owners manual. it shows the set of circuit breakers that I am looking for. Specifically the one that powers the compressor. Let me know what you think. Kenneth
1987_345 is offline   Reply With Quote
Old 02-17-2011, 10:20 AM   #45
AirRowan's Avatar
Key West , Florida
I will check when I get home. I am at work in the BVI and the rig is in Key West so I am only going off memory.
josh
Old 02-17-2011, 05:40 PM   #46
Kenneth
1987_345's Avatar
Waxahachie , Texas
Thank-you Josh
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Abby gets all the attention Top 1970 -1973 Ambassador 254 01-01-2016 05:07 PM
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Any advice on truck caps? (aka camper shells) ARMYOFME Tow Vehicles 73 07-18-2011 11:41 AM
AS280 - Mystery Button on Dash dalefox Classic Motorhomes 42 03-15-2011 05:24 PM
