12-04-2009, 08:31 PM
1989 34.5' Airstream 345
Jamestown
, Kentucky
anyone use the Long, oil filter, or twin remote
After all the talk of Heat and issues witht the Starter ?
I got to looking at the location of the Oil filter, someone placed a heat shield on Mine so I sanded it down and re painted with High heat Grill, paint when I replaced the filter with a Wix unit.
I got to thinking of a remote unit mounted away from the headers in cooler air and Summit and others offer Twin units that might also help.
More Oil, Cooler with more air flow.
Anyone do something like this ???
12-04-2009, 11:21 PM
Retired.
, At Large
I've used the longer filter, both on our TV and on several friends' motor homes. Our TV has an in-radiator oil cooler, and I see no reason why you couldn't use an oil cooler kit on your motor home.
12-05-2009, 05:17 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Yes....Like this.
Put this on our 95 Burb 454.
12-05-2009, 07:52 AM
Princeton
, New Jersey
I have mounted my filter under the driver seat for additional cooling and ease of access.
One picture shows the adapter and the tight access of the old filter and the other shows the new mount.
2004 Excursion 4x4
12-05-2009, 09:52 AM
Las Vegas
, Nevada
I have the Amsoil kit that includes stock and bypass filters, both spin on, on base plate mounted under radiator area on our 345 w/454. The 'stock' is just that and the bypass is almost 1 1/2 the size.
I'll try to find the Amsoil kit part #'s if anyone is interested.
12-05-2009, 10:38 AM
Jamestown
, Kentucky
Great information and Pictures everyone, Thank You !
These are all viable and effective options
John
12-05-2009, 10:41 AM
Jamestown
, Kentucky
Howie, do the hoses restrict the changing of your Starter Motor ?
12-05-2009, 11:01 AM
Princeton
, New Jersey
No This was a 6.5 diesel and the original filter position was on the drivers side and the starter on the passenger side. The reason for the change was for ease of access without draining oil all over the front drive shat U joint.
That engine has an after market intercooler and factory oil cooler.
2004 Excursion 4x4
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Oil filter report
Astrodokk |
Classic Motorhomes |
11 |
10-03-2011 07:29 AM |
Oil Filter Study
ViewRVs |
Mechanics Corner - Engines, Transmission & More... |
32 |
03-11-2010 06:26 PM |
Oil and Filter Change
gypsychris |
6 |
05-24-2008 08:30 PM |
Oil Filter
cooperhawk |
8 |
11-03-2003 12:57 PM |
Onan 4k 1979 Oil Filter?
RichardT |
2 |
09-28-2003 07:50 AM |
