Old 09-06-2016, 01:47 PM   #1
1987 34.5' Airstream 345
KC , Missouri
Anyone know the Alcoa Wheel Specification?
I am going to put a new tag on my 345 and since the hub is ruined and only 8 bolt hubs are available I have found a manufacturer that can make a wheel that closely resembles the Alcoas, i.e. 8 bolts but with 10 "hen" holes as the Alcoa's have.
Does anyone know the numbers for backspace and offset for the Alcoas?
Thanks!
DHC1 is offline   Reply With Quote
Old 09-14-2016, 06:05 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Backspace is 8.127" and offset is 5.000"
This was actually a test. I kept getting blocked when I tried to post the above info. I tried to send it in a PM and it was also blocked. I was able to get the info to DCH by email.
I did report the block to the administrator and they tried a few things and ask me to try again to see if the problem was solved and the post worked so all is well.
Cheers, Dan
~ Margaret Thatcher ~
Canadian Specification Models remphoto 2005 and newer - Bambi all models 14 10-28-2015 01:17 AM
Ride height specification Tony Lee Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 04-04-2013 06:27 AM
Bearing grease specification? Safari 62 Axles 7 10-12-2009 02:51 AM
airstream safari 1968 spare tire and wheel specification hockeyrink Wheels, Hubs & Bearings 7 05-18-2008 11:11 PM
