Old 11-20-2009, 11:45 PM   #1
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
anybody use Hendersons SuperSteer ???
Why SuperSteer® Steering Controls Work So Well
Straight bushings in standard bell cranks can’t be preloaded like a tapered roller bearing. This means a certain amount of clearance always allows play between the bushing and shaft.
The Difference: The SuperSteer® Bell Crank uses tapered roller bearings on a hi-strength steel shaft. It’s installed with a pre-load so it’s much tighter and allows far less wear.
Endurance Tested: A test proved these Bell Cranks 19% tighter than a set of rebuilt bell cranks with simple bushings. The high-quality tapered roller bearings remain tight with no lateral (side-to-side) or vertical movement after testing. The SuperSteer® unit outlasted the OEM unit many times over, which justifies its lifetime warranty.
Drivers Who Installed Them Are
Sold On SuperSteer®
After a SuperSteer® installation, one motorhome owner commented his motorhome steering control was much tighter and more responsive. More important, he felt considerably less fatigued after driving.
Bud Weisbrod has some choice
thoughts about bell cranks here
SuperSteer® increases motorhome steering control noticeably over stock OEM bell cranks.
Life-Long Warranty
These SuperSteer® Bell Cranks are warranted as long as you own your coach.
John H. is offline   Reply With Quote
Old 11-20-2009, 11:50 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Sold On SuperSteer®
Life-Long Warranty
Hi John, I'm a little confused here. Are you posting an ad or asking a question?
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-21-2009, 12:11 AM   #3
Images: 13
Asking a question ! I am taking the 345 into Columbus Monday and I see some posters visiting about Bell Crank Housings ??? so I did a search and came up with this Co SS. and I see that camping world sells them also ? My 89 only has 50,000 mile on her chassis so would these be worth the $$$ to install ? Has anyone done this ????
Old 11-23-2009, 04:57 AM   #4
John,
I have one installed on the drivers side on our 310. When we bought our 310 the steering was so bad it was scary to drive. These things cost about $310 each to replace. Since there were so many bad components on our 310 I replaced the worst parts first. There is no doubt that the SS units are better than factory components. However I managed to find a shop that had replacement bushings and seals for the factory bell cranks. I bought enough to do our 310 and the Argosy.
I'm pretty sure the factory bell cranks are no longer available and the same for the bushings and seals, no longer available. The SS units are about the only option out there. Also the bell crank arms on driver and passenger side are no longer available. SS does re-manufacture these units, not cheap but they are about the only game in town.
I'm just glad someone is providing these important parts.
Old 11-23-2009, 01:27 PM   #5
Images: 13
Thank You Brad, Yes, Just to find replacement parts is getting tough ! I can see that.
I am waiting for a call now from Columbus Brake and spring to see if I Need any new parts.
We should be coming down through Richmond Wed. afternoon, evening sometime Brad
John
Old 11-23-2009, 06:03 PM   #6
John
Keep your fingers crossed they don't find anything wrong.
We're heading to Texas for Thanksgiving sometime Wednesday. Depends on when we get off work and all that.
Have a nice Thanksgiving!
SuperSteer Coil Springs gloran Land Yacht/Legacy Motorhomes 0 05-11-2008 08:30 AM
Supersteer is not the only game in town bkahler Mechanics Corner - Engines, Transmission & More... 5 12-13-2007 06:56 PM
