Old 04-19-2005, 06:15 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Anybody else got one of these?
Hi,
Under the couch of my 84 310 Limited MH I find the broken electrical box show in the attached pictures.
Anybody know what it is?
ID:	11656   Click image for larger version
guy99 is offline   Reply With Quote
Old 04-19-2005, 07:00 PM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Do you have a doorbell button your grab handle at the door?
Your picture may be the remnants of a door bell ringer.
some need need both 120 volts and 12 volts
smily is offline   Reply With Quote
Old 04-19-2005, 07:43 PM   #3
guy99's Avatar
Images: 16
Yes, I do have such a button. However, the box in question has no remnants of any noise making device. It does appear to have had slots to hold batteries.
Old 04-20-2005, 05:31 AM   #4
Still Working
smily's Avatar
1994 36' Classic 36
Doorbell
I am almost certain that it is a doorbell. The ringer parts are gone. The wires you see are two for source volatge and the other two go to the doorbell button.
Use your Ohm Meter and verify. have some one push button and you will see continuity between two smallest wires.
The slots for "batteries" are not for batteries, they retained the little iron bars that ring when struck by striker.
I have replaced one with a typical house doorbell before. easy to do.
Old 04-20-2005, 06:44 AM   #5
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Yes
Yes, it is a doorbell. MY 85 34' Limited Trailer has a button on the door handle, and under the front sofa, there is the doorbell. I just bought a new household doorbell to wire into it. I think the doorbell came on the Limiteds
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 04-20-2005, 07:10 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
sure is, my door bell looks like that also, and is located in the same spot. I had to replace my switch a couple of times as they burn out for some reason. The bell device seems like a pretty standard item to replace with another or update. Then again does anyone really use the bell? It was never very loud.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-20-2005, 09:43 AM   #7
guy99's Avatar
Images: 16
Thanks guys. You have solved two mysteries. First, why doesn't the doorbell work and where is the fuse for it, and, second, what is that busted up thing under the couch?
Old 04-20-2005, 03:54 PM   #8
LeeMo's Avatar
Acworth , Georgia
Post Ding Dong!
...The witch is dead...
LeeMo
1979 24' Excella Motorhome
LeeMo is offline   Reply With Quote
Old 04-21-2005, 07:43 AM   #9
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Best thing is now I know how to fix my door bell!
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 05-18-2005, 10:15 PM   #10
1990 34' Excella
Windcrest , Texas
Rob
This may seem like a simple question, but don't house doorbells run on 110 AC? I checked mine in the AS and it runs on DC voltage, so where would I get a replacement?
Thanks again,
Mitch
Swanny is offline   Reply With Quote
Old 05-19-2005, 06:29 AM   #11
1994 30' Excella
[QUOTE=Swanny]This may seem like a simple question, but don't house doorbells run on 110 AC? I checked mine in the AS and it runs on DC voltage, so where would I get a replacement?
Yes and no. Your door bell is connected to 110 but there is also a 12V transformer in-line before it gets to the chime. You should be able to buy any 12V doorbell and it will work on your 12V system.
Chaplain Kent
Old 05-19-2005, 07:04 AM   #12
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Funny thing....my doorbell started working yesterday for no apparent reason. I love it when things fix themselves.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 05-19-2005, 07:12 AM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
My switch worked for about 6 months after I replaced it, then died. Does anyone ever ring it anyway?
AIR #005
retired!
Old 05-19-2005, 08:42 AM   #14
Greetings. For many years I have used door bell transformers for low voltage power supplys for thermostat controls. Unless they have changed since I retired, they are 24 volt transformers. the doorbells are also 24 volt. so they would be very weak sounding on 12 volt. Slonezy
slonezy is offline   Reply With Quote
