Old 04-03-2011, 11:44 AM   #1
1985 34.5' Airstream 345
Lafayette , Indiana
Any ideas for a new gas tank
This last summer on our vacation we developed a leak in our gas tank (1985 345 motorhome). We had it repaired but it is continuing to slowly leak. We need a new or used tank. Any suggestions or ideas much welcomed.
Kandace
Kandacelyn is offline   Reply With Quote
Old 04-03-2011, 11:56 AM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Kandace
Check with a local radiator shop as they often do fuel tank coating as well. They typically clean out your original tank, then apply some sort of coating on the inside & outside. They are often guaranteed for as long as you own the vehicle.
Colin
Colin H is offline   Reply With Quote
Old 04-12-2011, 10:32 AM   #3
Kandace
Kandace,
We have an 86 345 that we are parting out and the gas tank is still installed. I do not know the condition of it but can take a peak if you're interested.
Richmond, KY
Old 04-12-2011, 11:34 AM   #4
1988 32.5' Airstream 325
calgary , alberta
Good morning! I had a similar problem, you may have them just check the rubber filler hose from cap to tank, that seems to be problem on mine, Have not found a new replacement yet! Jonathan
jhenry is offline   Reply With Quote
Old 04-16-2011, 08:15 AM   #5
Lafayette , Indiana
Hi Brad, excited to get your response. Has the 345 been used recently or has it been sitting idle for some time. We would like to get more information- do you have personal email or contact information so that I or my husband could contact you to set up a time to come down and take a look. I don't know if you have awnings, radiator overflow tank, fridge, we could have a long laundry list- My personal email is klgeller7@aol.com.
Looking forward to hearing from you soon.
Kandace
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 07:50 AM
New Slant on Tank Sensor Cleaning... Mexray Waste Systems, Tanks & Totes 5 01-30-2011 02:07 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 05:10 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 07:00 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 10:19 PM
