04-06-2020, 05:01 AM
#41
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Haldex 19842 should work for you, check diameter and length.
05-18-2020, 08:49 AM
#42
Roswelll
, Georgia
Tire pressure
I have installed new air bags on my 370 LE, a new Gast air compressor and a new stainless steel air tank. The control rod the height control valve on the front axle is not long enough to inflate the new air bags completely, so I am adding an extension to the plate the rod connects to.
I also am adding Crossfire valves for the drive axle to balance the air between the tires on each side. What tire pressure should I use, assuming a "normal" load on the axle? The manual says the max tire pressure is 95 lbs, but I have not driven my 370 enough to get a feel for what works best for this motor home.
05-18-2020, 05:10 PM
#43
north blenheim
, New York
Which tires are you running ?
05-19-2020, 06:35 AM
#44
Roswelll
, Georgia
Tire pressure
Bob,
You asked what tires are on the motor home. The tires on the drive axle and tag axle need to be replaced due to age. What tires do you recommend, and what tire pressure for those tires?
05-19-2020, 03:37 PM
#45
north blenheim
, New York
Charly and I are both running the Michelin P225/70R19.5 100 PSI all around. The Michelin LT tire is the only one made with a speed rating of over 75 MPH. Regards, Bob
07-25-2022, 02:41 PM
#46
Haarlem
, Na
Sorry for the revival of this thread, just trying to get some information,
I've just bought a 370LE, and going to export it to the EU but it's a bit rough, the former owner is trying his best to get it up and running, engine is running,(so that's the running part) but now the up. I've got a new GAST Compressor (the one posted above) and now the front bags are leaking, did anybody post the Firestone numbers on the front bags? Would want to order them to get them fitted to get it lifting!
Also checking on the Michelin tyres, but it seems these are not longer produced.
If anybody could advise me on the front bags and point me to a good tyre? Would be realy appreciated.
07-25-2022, 05:37 PM
#47
north blenheim
, New York
Who’s 370LE did you buy ? Just want to keep my records up to date. If you could post your VIN number that would tell me. Charly (Streamquest) and I bobmiller1 are both running Michelin 270/70R19.5’s. I think that’s right but I check when I get home, I’ve been in trailer mode for the last year working on my 05, 34’ Classic S/O. I’ll also look up the bag numbers for the front for you. Both of us changed both front and rear bags.
07-25-2022, 11:44 PM
#48
Haarlem
, Na
Thanks for the reply, I'll pm you the Vin,
Great if you could post the partnumbers!
