Old 02-06-2012, 10:04 PM   #15
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
I guess it might have the ability to hold moist air, but it is never wet to the touch like bat insulation that goes soggy.
I agree that the SM product is easier to work with and I would use it on any retrofit.
This is another shot of the same Airstream motorhome. If you enlarge this shot you can see the insulation through the cutout above center of picture. It has a blue color to it and looks to be a SM product in this unit? You can see the boards of insulation if you look close.
So the SM product did not do much for this unit.
Dave
"Just a comment about bead-board insulation. I work in the EIFS industry (Exterior Insulation Finishing System) we work with both types of insulating board - styrofoam and Expanded Polystyrene (EPS) or white bead-board. The way that EPS board is manufactured, bonding the larger beads together, acutally makes it more susceptible to holding moisture than styrofoam which is Extruded Polystyrene and is stronger, denser and has a higher R value than bead board. But as you stated, the real problem is: once moisture gets inside the walls or ceilings it is very difficult to dry out.[/QUOTE]
Old 02-16-2012, 09:18 PM   #16
masseyfarm's Avatar
Images: 56
This document confirms the 8' wide 1992 Land Yacht on the Chev Chassis was built with tubular steel construction in the roof and sidewalls, welded to the Chev Chassis, and Styrofoam board insulation was used.
Dave
http://www.airstream.com/files/libra...fb5f31e34a.pdf
Old 12-11-2014, 03:04 PM   #17
1995 33' Land Yacht
Tempe , Arizona
Question 1995 Airstream Land Yacht 33
I continue to require the following body parts for my 1995 Land Yacht Bus: I could not upload the photos of the rear right panels. Lonnie
ID:	228380   Click image for larger version
lstepp2 is offline   Reply With Quote
Sloped Roof Under Air Horns Johns5711 Land Yacht/Legacy Motorhomes 7 07-27-2011 07:02 PM
will stainless steel patches work on the aluminum exterior? vanvickl Ribs, Skins & Rivets 4 07-04-2011 01:25 PM
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
Replacing Steel Wheels with Aluminum crookedroad Wheels, Hubs & Bearings 8 02-03-2011 11:27 AM
aluminum or steel rayandre LP Gas, Piping, Tanks & Regulators 3 01-01-2011 11:55 AM
