Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 09-23-2012, 11:25 AM   #1
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Alternator Generating High Voltage
It's been a really long time since I've posted here. Feels like an old pair of Jeans
Chasing a charging issue lately and have run into a situation where the Alternator is putting out 40+ volts at 1200 - 1500 RPM. Even higher at 2000 RPM.
Here is what has been done so far:
Alternator is a 12V 150 AMP Lestek. Took it into the shop this week for a bench test, totally dead so I had it rebuilt. New brushes, stator, bearings, etc. Bench tested AOK.
Replaced original voltage regulator (Echlin) with a NAPA Echlin VR-428 (Ford replacement)
Checked, double checked and triple checked all of the wiring which is setup as follows:
Alternator BAT to Solenoid/Battery Junction
Alternator GRD to ground shared by Voltage Regulator
Alternator FLD to "F" on Voltage Regulator
Alternator STA (unused)
Voltage Regulator A+ from Battery/Ignition
Voltage Regulator S from Ignition
Voltage Regulator F from Alternator F
Voltage Regulator I (unused - no ignition light on my 34%)
Test Results Ignition Off
VR A - 12.05v
VR S - 9.83v
VR F - 11.7v
Alt BAT - 4.2v
Test Result Ignition On
VR A - 12.03v
VR S - 9.79v
VR F - 11.68v
Alt BAT - 3.37v
Test Results Engine On (1200 RPM)
VR A - 11.9v
VR S - 9.65v
VR F - 11.58v
Alt BAT 57.3v
I've run the same tests with the Alternator output separated from the battery isolater as well just to rule out an open or short in there.
So, I'm looking for any additional tests, things to check, etc. As always, any advice is appreciated.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 09-23-2012, 11:36 AM   #2
dadstoy's Avatar
_ , _
Hi Steve. Good to see you are still out there! I just replaced my alternator as well.
I'm curious why you are running an external regulator? Don't all modern alternators have their own built in regulator?
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
dadstoy is offline   Reply With Quote
Old 09-23-2012, 11:42 AM   #3
RivetAddict
swebster's Avatar
Still here
The Lestek alternators are a high amperage alternator for low RPM use on RV's, Boats, etc. and therefore use a heavy duty external voltage regulator. It's a bit old school for sure, but it's a common setup in RVs running these alternators.
I thought about replacing it with a "normal" Chevy alternator but would loose the high amp/low RPM features.
FWIW - anyone with a Lestek, the company was bought out by Penntex and they offer cross reference replacements (Alternator Cross Reference)
Steven Webster
AIR 1760
Old 09-23-2012, 11:44 AM   #4
72 tradewind's Avatar
1972 25' Tradewind
Willis , Texas
Images: 8
The last time I saw this, the charge wire from the alt to the battery positive terminal was burned open...Do you show 40 volts at the battery? You should have no more than 14.8ish. If is only 12v -ish the wire is open from the alt to the battery. P.S. while the engine is running....
72 tradewind is offline   Reply With Quote
Old 09-23-2012, 11:55 AM   #5
RivetAddict
swebster's Avatar
I show approx +/- 12v at the battery in all three scenarios (ign Off, ign On, Engine On). I should add, the battery has not been charging (which is what led to this process of testing, rebuilding and replacement)
Sounds like I need to start tracing the battery wiring. Any tips?
On Edit - The Battery was also newly replaced
Steven Webster
AIR 1760
Old 09-23-2012, 12:42 PM   #6
Welcome back Swebster!
I have read your posts with interest going back years... like Brad, you guys forged the path us newcomers are widening!
Mine has some charging issues too, and has the Ford Voltage Regulator mounted on the radiator support, so I will be interested to follow your diagnosis!
Old 09-23-2012, 12:54 PM   #7
Dean, while dismantling the 345 I found that it also had a Lestek alternator with external voltage regulator. It's a 105 amp output alternator. At the time I found it I was wondering why it had an external regulator so I'm glad Steve was able to clear that up for me.
I just might have to use it on the Argosy.
By the way, welcome back Steve!
1975 24' Argosy Motor Home
Old 09-23-2012, 02:46 PM   #8
RivetAddict
swebster's Avatar
Bingo. Found the open in the Battery Isolator. Bypassing the isolator gives me 14.3v - 15v at the battery while running. Thanks guys, it's been a while since I've needed to post here but as usual I got some sage advice within minutes.
Time to order a replacement isolator.
Steven Webster
AIR 1760
Old 09-23-2012, 02:52 PM   #9
Good news!
Is that the one mounted on top of the engine, close the alternator?
Old 09-23-2012, 02:56 PM   #10
RivetAddict
swebster's Avatar
Well on mine the isolator is mounted on the "firewall", drivers side. It's a blue finned solid state isolator. Pulling the old one out it appears it's under-rated for the higher amperage alternator...betting this was the cause of many a battery and charging problem over the years.
Looks like this one but dirty
Found a replacement online rated for 160 amps for $66.
Steven Webster
AIR 1760
Old 09-23-2012, 03:02 PM   #11
RivetAddict
swebster's Avatar
Keyair, I think you might be referring to the solenoid mounted to the alternator bracket. I replaced about five of those in rapid succession (vibration + heat = bad)....finally dumped the Chevy solenoid and went with a Ford that I mounted on the frame. Have not had any issues with than in years.
Steven Webster
AIR 1760
Old 09-23-2012, 07:16 PM   #12
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Hi Steven, welcome back. I returned after a few years away myself. I sold my 79 bought Dennis's 345 in May and have been working on it since. Did you decide to keep your 345, I saw it up for sale not long ago.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 09-23-2012, 08:24 PM   #13
RivetAddict
swebster's Avatar
Thanks Peter. Yeah, we've certainly been under utilizing the 345 the last couple of years. May re-list it, not really sure at this point. Frankly, the selling process was a bit frustrating. Lot's of tire kickers, time wasters and dreamers. At some point it's not worth selling it as I could get back into it and enjoy every second of it. Just balancing working on the Airstream against working on everything else.
Gotta say, really nice to jump back on air forums and feel like it's only been a few days since I last posted. Such a great group here.
Steven Webster
AIR 1760
Old 09-23-2012, 08:39 PM   #14
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Steve,
Which amperage isolator did you end up purchasing? As well, where did you find such a great price?
Thanks, Derek
Old 09-24-2012, 07:28 AM   #15
RivetAddict
swebster's Avatar
Derek,
Here are a few: Sure Power 160 Amp Dual RV Battery Isolator
Steven Webster
AIR 1760
