Old 06-21-2013, 10:13 AM   #1
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
Alcoa center cap
Any one out there know where I can find a center cap for a rear 19.5" Alcoa 10 lug wheel? How it weaseled off the coach seeing its held on with a ring secured by all lugs?????? Alcoa does not have the old style any more. Brad, you are the best bet . Lost it somewhere between Portland and Glacier Nat Park Montana Thanks in advance!
raveson is offline   Reply With Quote
Old 06-21-2013, 10:58 AM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
These are the ones I use. http://www.southwestwheel.com/store/p-1800-011912.aspx They do have an Alcoa sticker instead of the Airstream sticker.
Cheers, Dan
~ Margaret Thatcher ~
Old 06-22-2013, 11:50 AM   #3
Sorry, the ones from the 345 are long gone
Looks like the link Dan provided is what you need.
Old 06-22-2013, 11:56 AM   #4
1995 36' Classic 36
Ludington , Michigan
Check the source in my parts thread.
Kota is offline   Reply With Quote
Old 06-27-2013, 04:41 PM   #5
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
If you were trying to purchase new aluminum rims what would you have to specify? P30 chassis 19.5x6" 10 holes. Any other information needed for ordering aluminum rims that would match existing, like a model or style number?
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 06-27-2013, 05:20 PM   #6
Alcoa no longer makes the wheel but these guys sometimes have them. Rickson Wheel Manufacturing
It is the 7.25" bolt circle and 5.25" bore, part # 761000-1 &-2.
Cheers, Dan
Old 09-11-2013, 11:38 AM   #7
1985 31' Sovereign
san antonio , Texas
Wheels
Looking to change my wheels from steel to aluminum wheels . I have a
1982 280 airstream motorhome . (P30 chassis wheel is 19.5 +6 , 5/10 on 7.25).
Any one know where I can buy new aluminum wheels. Not opposed to changing hubs for new wheels. Any info would be appreciated.
stephrnrvt is offline   Reply With Quote
Old 09-15-2013, 08:05 AM   #8
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Yes having aluminum rims is nice indeed but buying a set of rims from Rickson can get very expensive indeed, $3000+ for tandem and $2000+ for single axles.
Please keep in mind that you CANNOT run both alloy rims on your dual rear axle as the wheel studs are too short and the alloy rims will eventually weld themselves together with corrosion if you don't use a spacer (which can be dangerous).
I had thought about going with alloys but wanted the ability to rotate ALL my wheels, which you can't do with alloys, and also felt my money would be better spent else where.
If you're looking for a real quality SS wheel simulator, these are really good quality and far easier to keep clean than alloy. A whole hellava lot cheaper too, under $300 for the kit. They also sell air extenders for the rear wheels which makes taking pressure readings for the dually a breeze.
:: Phoenix USA :: DOT SETS
Looking for item NG961
IMHO If you can get the alloy's for a great price on the cheap, get them. If you're spending $3000+ for a set of alloys to reduce your unsprung weight by 20 lbs per wheel to save gas; it would take a millenium to recoup the $3000+ spent.
Cheers
Tony
Old 09-25-2013, 08:29 AM   #9
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
Hey Smartstream
I bought two of the 011912 hubs and finally had the time to install them yesterday evening. However, the retaining ring which holds the existing hub is too small to fit over the new hub, by about a 1/8th of an inch! The new hub snugly fits over the old one.
I called southwestwheel this morning and they don't stock the retaining ring.
The parts person was not really helpful and all he could say was they didn't carry this part and didn't know of who did! <vent>Some people are just not very helpful</vent>
I've done a little search but nothing so far. If all else fails I may just have two machined locally.
elbundi is offline   Reply With Quote
Old 09-25-2013, 11:05 AM   #10
Originally Posted by elbundi View Post
Hey Smartstream
Have you got a couple of pictures, I'm not exactly sure what you are referring to as the new hub? On mine the washer part of the lug nuts is what actually holds the center cap. It's not much of a lip but it seems to hold it pretty tight.
Cheers, Dan
Old 09-25-2013, 08:41 PM   #11
elbundi's Avatar
Leesburg , Georgia
Not sure what to do next other than clean things up for now.
Maybe strip and re chrome the existing hubs. Those retaining rings are also on the front (5 hole), duals (10 hole), and tags (10 hole) on an '85 345.
I'm sure the washers on the lug nuts could hold the new hub in place but I don't think it would be as neat as how Airstream had originally set it up.
Hope the pictures help illustrate.
ID:	196375   Click image for larger version
ID:	196377   Click image for larger version
ID:	196379   Click image for larger version
Old 09-25-2013, 09:01 PM   #12
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Is there any way the inside of the retainer ring can be made a little larger to slide over the new hubs?
Old 09-26-2013, 07:37 PM   #13
elbundi's Avatar
Leesburg , Georgia
You mean make 10 snips and fold up? That's a thought.
I bought some 'chrome' paint and tried it on a rusty lug nut cover. Not so shiny on close up, a mask at best.
Old 09-26-2013, 07:45 PM   #14
I took a couple of pictures of my wheels. Please excuse how dirty they are.
The front caps fit over the ring and are held by the washer part of the lug nuts.
ID:	196448 Click image for larger version
My rear wheels don't use the ring but the cap fits the same way.
ID:	196452 Click image for larger version
If you look close you can see the edge of the caps but stand back a few feet and they look like any other set up. It amazes me how little the lip is that holds the cap but it seems to do the job.
Cheers, Dan
