Old 05-30-2018, 12:56 PM   #1
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Alcoa Aluminum Wheels 19.5 X 6
I have started looking for the Alcoa aluminum rims and accessories for my 1983 310. I have read several post and have seen part numbers for front and rear wheels. 761002 Rear, 761001 front. Is their two different rims for the P30 chassis. I know this is going to be a long process for locating wheels so I wanted the facts on what I need. Thanks Jim
cole3444 is offline   Reply With Quote
Old 05-30-2018, 02:51 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
There is also a 761003, the difference is that the 001 is polished on the outside, the 002 is polished on the inside and the 003 is polished on both sides. Let me know what you find cause I am still looking for 3 more for my 325LE. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 05-30-2018, 03:11 PM   #3
1971 31' Sovereign
1972 31' Sovereign
bobmiller, thanks for the info, I will keep an eye out for any of the three styles. If you find extras let me know. Maybe someone will see some for sale and let us know. Jim
Old 05-30-2018, 04:19 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Always coming up for sale; just one little problem; they tend to be attached to an Airstream motorhome. Not to say you couldn't buy the motorhome; attach said alloys to yours; attach steel wheels with nice simulators to the motorhome you bought, and flip it for a grand more. It would get you a set faster.
Just one thing to watch for.......cracks, especially between bolt holes; you take a chance buying sight unseen.
If you can swing it, buy a 325 or 345 and that will give you two spare. Pity you didn't have $2,500.00 a couple of weeks ago; the perfect 325 was all there.
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 05-30-2018, 06:43 PM   #5
bobmiller1's Avatar
Missed that one by minutes Tony, Regards, Bob
Old 06-18-2018, 01:00 PM   #6
1971 31' Sovereign
1972 31' Sovereign
I now understand how hard it is to find these aluminum wheels for our motorhomes have had no luck in any shape form or fashion. I have looked at pics of your motorhomes and I assume the front wheels are 5 lug and the rear 10 lug???. I have simulators on right now and don't dare to take them off because I lose things when I have no reason to take things off. Please let me know if I am right. Thanks Jim
Old 06-18-2018, 04:10 PM   #7
bobmiller1's Avatar
All wheels are 10 hole (Alcoa) for our application, 370LE, 360DP and possibly some others are 6, but all Chevy P30, P32 chassis are 10, the front hub cap hides the 5 that are not used, Regards, Bob
Old 06-19-2018, 06:37 AM   #8
1971 31' Sovereign
1972 31' Sovereign
Bob, Thanks for the clarification, was a little confused looking at pics of 310's and others on the site and internet some showed 5 lugs on front 10 lug on back and my simulators were all 10 lug. Just another day in the Airstream world. Now I can look for the correct rims. Will let you know if I find any. Jim
Old 06-29-2018, 02:19 PM   #9
1979 28' Airstream Excella 28
PRESCOTT , Arizona
Alcoa wheels vs steel wheels, lug bolts
So it appears that Alcoa are thicker and and the lug nut lies on top of the rim vs steel that is beveled . So plan on changing out your lug bolts front and rear . I'm dealing with 19.5 . Don't know about 16". Any body know the exact length needed or used on these hubs and rotors 28 Excella 1979?
nazguy is offline   Reply With Quote
Old 06-29-2018, 07:20 PM   #10
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I changed from steel to aluminum and the original studs are long enough, barely. You still use a steel wheel for the inner dual. This is the lug nut. https://www.southwestwheel.com/p-1805-39946.aspx
Cheers, Dan
~ Margaret Thatcher ~
Old 06-30-2018, 08:13 AM   #11
PRESCOTT , Arizona
Thxs, Yes those are the lug nuts I have .. Just looking a little ify with seeing the inside nut threads instead of the bolt threads. Would you have any pictures of the nuts on the rim ?
Old 06-30-2018, 11:45 AM   #12
1986 34.5' Airstream 345
Londonderry , New Hampshire
Here are shots from my 345.
Front wheel lug nut;
Dual axle lug with steel inner wheels;
Tag axle lug;
Hope this helps,
Pete.
Air345Fly is offline   Reply With Quote
Old 06-30-2018, 01:03 PM   #13
bobmiller1's Avatar
They look pretty rusty...I would recommend removing and never-sneezing them, and a good polish job on the rims and caps.....just saying, Regards, Bob
Old 06-30-2018, 01:15 PM   #14
You are quite right! That one goes on my todo list at position 563.
My thought on lug nuts is that you don't want them to be lubricated.
That might encourage them to work their way off. Does that make
sense?
Pete.
Alcoa Aluminum wheels with Brand new tires mike.juron Airstream Classifieds 0 07-07-2017 07:34 AM
4 Airstream Factory Alcoa Aluminum Wheels scott05 Airstream Classifieds 0 09-03-2016 08:26 AM
4 Airstream factory Alcoa Aluminum wheels dishwasher Airstream Classifieds 0 08-07-2016 09:12 AM
4 Airstream factory Alcoa Aluminum Wheels Surfas Airstream Classifieds 0 06-14-2015 04:11 PM
4 Airstream factory Alcoa Aluminum Wheels stanp001 Airstream Classifieds 0 04-11-2015 07:22 PM
