05-24-2011, 01:05 PM
Foothill Ranch
Alcoa Alloy wheel Spec?
Was offered a set of Alcoa wheels, but I now know they were not right...
What is the size and width for future reference?
05-24-2011, 04:40 PM
1982 28' Airstream 280
Port Angeles
The early P-30 is 19.5"x6". The lug bolt circle is 7.25" and the center hole is 5.25" and off set is 5.08". The rear axle has 10 lug nuts and the front has 5 lugs. I'm not sure what the tag uses.
If you run across a set you don't want, I'm looking for some.
Cheers, Dan
05-24-2011, 07:22 PM
1989 34.5' Airstream 345
Jamestown
, Kentucky
The Tag should use the same wheel as the drive axle.
03-14-2013, 02:45 PM
Foothill Ranch
I know this sounds wacky at first, but finding 19.5" Alloys is too darned hard... yet 22.5's are pretty common.
Now, the 22.5's are not available with our 7.25 PCD...
Anyone ever seen an adaptor?
Oh, and before anyone says it...
A 225/70 R19.5 and a 225/70 R22.5 tire is pretty close on rolling diameter
About 2 revolutions per mile difference.
03-14-2013, 03:54 PM
Port Angeles
Try these guys. Rickson Wheel Manufacturing
This is the spec. and they have them.
Cheers, Dan
________________________________________
"Socialist governments traditionally do make a financial mess. They always run out of other people's money. It's quite a characteristic of them."
~ Margaret Thatcher ~
03-14-2013, 06:06 PM
1993 33' Land Yacht
Midland
, Michigan
I think Rickson wheel sold out to another company, that doesn't offer aluminun wheels any longer.
03-14-2013, 06:13 PM
Port Angeles
I don't know about that but the web site is still up.
Cheers, Dan
03-17-2013, 06:25 AM
1989 37' Airstream 370
Louisville
, Kentucky
Keyair
You may need to check your math the 22.5 is 3 inches larger. With the same width and aspect ratio that makes the overall diameter 3 more inches. The real problem you will likely run into is Clearence. The 22.5" wheels are also wider than the standard 19.5's. After 3 blowouts in 3 trips I looked at this option but found it would be impossible without major body modifications.
03-17-2013, 11:00 AM
Foothill Ranch
Hi Oliver!
Wow, a 370 owner!
Impressive!
I agree width could be an issue, but here are the specs for a 225/70 R19.5 tire and a 225/70 R22.5 tire.
Bob Dickman Tire Center - Motorhome Tires » Tires by Size
Both sizes quote a 6 to 6.75" rim width too.
03-17-2013, 04:01 PM
1993 33' Land Yacht
Midland
, Michigan
Keyair, I thought your 345 all ready had alloy wheels on it? I've been looking for some time and haven't been able to locate any either.
03-17-2013, 04:07 PM
Foothill Ranch
Nope, just steelies with chrome covers...
Interesting news is that I called a place friday who say they are tooling up for a steel adaptor for this conversion. They said later this year production will start.
03-17-2013, 05:07 PM
Louisville
, Kentucky
I think that may be a mistake. To My knowledge the lowest profile 22.5 is a 255/70r22.5. That tire is @ 37" in diameter the 225/70r19.5 is @ 32". If you do find a 33"-34" 22.5 let me know because I have 10 new 22.5 Alcoas ready to put on.
