Old 08-04-2012, 09:55 AM   #1
1979 28' Airstream Excella 28
Hooglanderveen , Utrecht
Airstream in Spain
Hi all, just let you all know that we made it to Spain in our in april bought MH
Lots of thoughts what to do to the MH...
I'm afraid many questions will follow.
Regards, jos
Josvin1 is offline   Reply With Quote
Old 08-04-2012, 02:50 PM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Ask any and all questions. Sure all here on the Forum will be happy to respond.
Good Luck, Derek
Old 08-04-2012, 04:34 PM   #3
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Hey Jos, did you drive from the NL to Spain? Post pictures of traveling through europe in a AS MH! Sounds like a great trip, have fun.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 08-04-2012, 07:30 PM   #4
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
¿Habla usted aluminum?
Ultradog is offline   Reply With Quote
Old 08-05-2012, 02:40 AM   #5
Yes drove it from NL, we are near Santander in the Pikos de Europa. Going to Potes today. Apart from some starting problems evrything go's well.
When i turn the key it only klicks and no startermotor.Checked the neg. pole but no differends.
I'm on wifi and don't know when i van sent new pictures.
Regards,jos
Old 08-05-2012, 10:28 AM   #6
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Does your starting problem only happen when the motor is hot? If so, search the forums for "hot starting" threads. Otherwise, check battery cable connections. Make sure that each connection from the battery to the starter and from the battery to ground is clean and tight.
Waipio Rim is offline   Reply With Quote
Old 08-05-2012, 02:18 PM   #7
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
This is most commonly a loose connection or poor battery charging.
Step 1 use multimedia to check battery voltage if over 12.5 (which is quite discharged) it should still turnover
Step 2 If voltage good, but not turning over, check hot battery connection. Use wire brush on positive terminal (be careful) and reset terminals ideally covering in petroleum Kelly
Step 3 If voltage low, re-charge or if stuck, you should have a solenoid in glove box to join coach and auto battery. Otherwise, you can join starter and coach via jump leads, but only use in emergencies
Mostly, it is poor connections
Boom Sounds is offline   Reply With Quote
