Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 09-02-2007, 02:37 PM   #21
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Tom,
Good point. The mechanical pump could be the issue in this case. Also I just recently had an ignition module go all wonkey on me. Worked, didn't work, worked.
Replaces with NAPA Heavy Duty Lifetime Warrantee verison for $30. Well worth it. Also solved my intermittant no start issues I've had for almost six months.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 09-02-2007, 03:31 PM   #22
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Originally Posted by ArStrm345LE
2007.08.22 UPDATE: I just got off the phone with the Mechanic and he said they had just re-timed the engine to 4 degrees before TDC. I respectfully mentioned to him that it was my understanding that the proper timing for this motor/moho was 8deg before TDC. He said they knew what they were doing as they have the proper documentation and they are an RV/auto repair shop. Are they correct? Can anyone possibly give me an intelligent response if the timing is indeed 8 before using the timing marks on the bottom of the engine using the 8th cylinder?
P.S. I couldn't seem to find the edit button for my above post to append this one. I apologise in advance for the double posting.
They are indeed correct. The proper timing for a 454 RV motor is 4*BTDC. If you were running a high performance 454 with 10.5:1 compression, you would set your timing at around 10*BTDC. If you find that your motorhome is sluggish, you might want to ask the mechanic to take a look at the timing chain. If the chain isn't as tight as it should be, consider a double roller timing chain. As for the motor running at bit warm (my L-82 350 Vette ran at 210 stock, and that was normal), have the mechanic take a look at the fan clutch. Fan clutches that work make a world of difference. I would also make sure that I had a 4 core radiator. Hope that helps.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 09-27-2007, 07:50 PM   #23
1985 34.5' Airstream 345
Frisco , Texas
Loss of fuel/Power on grade
I have an '85 345 classic that I'm intemately familiar with having rebuilt the engine myself along with a multitude of other mechanicals. I too suffered from the fuel flow problem and had always replaced the mechanical pump when the frustration grew. After 15 years, I finally figured out my demons. The electric pump in the rear near the fuel tank is a very weak push pump which means it cannot pull fuel from the tank. On my rig the fuel pumpl was mounted about 1/2 down from the top of the fuel tank. That meant that for the first 1/2 tank of gas, gravety works as designed and feed the pump. However once the tank is lower than the fuel pump the small electric pump simply losses its effectiveness and when a grade is encountered the fuel flow is almost shut down. To fix the problem I mounted a high quality race pump as low as possible on the frame near the bottom of the tank and surely below the fuel pick up. I've run three tanks through it since the modification and feel confident I could climb everest without a chug.
Hope it helps.
txraz is offline   Reply With Quote
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 01:39 PM
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 10:20 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
