Old 08-01-2011, 05:30 PM   #29
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
Originally Posted by AirRowan View Post
Baby steps.
-still faster than my snail pace
Won't take long to put it all back together!
lol
Wow, that's awesome AirRowan. Your blog too. Keep on inspiring. It's hot muggy and buggy here too and the classic always beckons when it's the hottest
elbundi is offline   Reply With Quote
Old 08-01-2011, 07:28 PM   #30
: sorcerer:
Old 09-09-2011, 12:51 PM   #31
AirRowan:
I am breathless after looking thru your Blog!
The Diesel Conversion and the Boat?
And I think I take on too much?
Goodness me!
I have a question about your 345...
You towed that heavy old boat, so you have an idea how the brakes on the MH stood up..
I am sure you will have a jake or exhaust brake option with your conversion, but with the extra weight, and your clear intention to tow, have you any plan to do any brake upgrade or mods?
Based on your "Go for it" attitude, i would love to know what you think you might do?
Old 09-10-2011, 12:31 PM   #32
AirRowan's Avatar
1986 34.5' Airstream 345
Key West , Florida
Keyair I am not rilly changing any thing with the hydraulic brakes just adding a diyode and a pot to the tag axel brakes. I like the pendulum brake controler (tag axel: has true concurrent braking) but there is no way to apply the brakes if you neet to (the pendulum only works if the primary brakes work) so with my system if you lose primary braking (belt brakes etc.) all u need to do is turn this pot and voila you have some brakes.
The duramax has exhaust brakes thanks to its variable vane turbo and the 6 speed allison that u can select the gear with on the column shifting button.
AirRowan is offline   Reply With Quote
Old 09-10-2011, 12:37 PM   #33
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
You got that bad boy on the road, yet?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-17-2011, 02:01 PM   #34
AirRowan's Avatar
Key West , Florida
First day back on the Airstream in 2 months. It is raining cats and dogs down here and i can not work on the boat (it is outside) so inside airstream it is :-).
Now if I could only remember all the parts/wires etc. :-(
I plan on moving back in this month so i need to get it closed up.
ID:	142983   Click image for larger version
ID:	142985   Click image for larger version
ID:	142987   Click image for larger version
ID:	142990   Click image for larger version
ID:	142992   Click image for larger version
Old 10-17-2011, 05:29 PM   #35
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Air, that is one HUGE undertaking on your part! Looks great so far. Can't wait to see the end result. Maybe you could video your 'maiden voyage' and post to YouTube?
Thanks, Derek
Old 10-17-2011, 07:32 PM   #36
Mike Leary's Avatar
Images: 11
It would sure be cool, since this is mostly a tech forum, to be able to enlarge pics to full screen size. MODS, can it be done? I currently have blank space next to this post, what for?
Old 10-22-2011, 03:22 PM   #37
1995 36' Classic 36
Ludington , Michigan
Interesting Thread! Can't wait to see how it comes out. I've retrofitted 3 classic vehicles with modern drivetrains. Two classic Broncos got 2000 Explorer 5.0s and a 68 Mustang got a 94 Mustang 5.0 HO. The wire harnesses were the most work.
Kota is online now   Reply With Quote
Old 10-22-2011, 04:24 PM   #38
Mike Leary's Avatar
Images: 11
Originally Posted by Mike Leary View Post
I currently have blank space to the right of this post, what for?
Still waiting for an answer, give it to Vin The Rookie to explain why. :confused
Old 03-17-2012, 11:39 AM   #39
AirRowan's Avatar
Key West , Florida
It runs!!!! But apparently I have exceed my upload allowance so i can not post any pics sorry :-(
Old 03-17-2012, 11:41 AM   #40
Thats great to hear!
Bet you are jazzed!
More info!
Old 03-17-2012, 12:42 PM   #41
AirRowan's Avatar
Key West , Florida
Where to start? (pun intended :-) About a week ago I first turned the motor over by jumping it at the solinoid; not to start it, just to move fluids around. Later on, after all systems were ready, I turned the key for the first time..... The lights came on the dash but as soon as it was turned to crank power went out :-(
Checked all fuses and relays and found that the crank relay had no ground. After two days of pulling everything apart and reading 90 pages of schematics, I found the problem. The only part of the original Airstream that I kept (dash systems/lights) was the wiper module wipers and switch. well the 5 pinned (2008 duramax) wiper motor conection plug had the ground for the crank relay!!!&@@) what if u had a short in the wiper motor and needed to unplug it? the truck would not run (dumb engineer)!
Later, I took it out on its maiden voyage and found that the tranny allison 1000 drinks a lot of fluid (4 gal) every gear it shifted into I had to add 2qts to get the thing moving again.
I plan on taking it out again latter today.
Old 03-28-2012, 01:19 PM   #42
AirRowan's Avatar
Key West , Florida
There is a video of it on my wife's blog svrowan.wordpress.com apparently there is no more space for photo up loads on this site.
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
Power cord length-recommendations? SilverHoot Electrical - Systems, Generators, Batteries & Solar 17 01-23-2011 02:39 PM
Progressive Dynamics Inteli-Power 4060 Power Center 68 Overlander Commercial Listings 0 01-21-2011 11:24 PM
max out the power? or not? bukib Land Yacht/Legacy Motorhomes 1 01-15-2011 08:46 PM
