Old 03-20-2007, 07:56 PM   #1
1988 34.5' Airstream 345
CUMMING , GA
Airbags r flat!
I hope someone can help. Just got my 345 out of the shop (a performance shop, not a RV shop) for a much needed hedman header and flowmaster exhaust as well as a brake caliper replacment. About 15 miles down the road I noticed I had no air suspension on the gauge. I have no idea where the compressor might be or if there is a compressor. anyone have any thoughts on how to remedy this?
wpapke is offline   Reply With Quote
Old 03-21-2007, 04:56 AM   #2
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
On my 310 the air compressor is in the left rear compartment door that has the electric cord. Others have had them in the generator compartment. Not a good idea to drive with no air. It will tear up the air bags, if they are any good, and is rough on the suspension.
Good luck. Best do a complete check on the air system and bags. If the bottom of the bags are cracked (aka dry rot) you need to replace them.
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 03-21-2007, 05:16 AM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Under the bed in the curbside rear corner
See this thread -
http://www.airforums.com/forum...ssor-8624.html
Do a search on "Air Compressor" - lots and lots of threads on this subject.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 03-21-2007, 09:09 AM   #4
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Here is another thread.
Fred Goes to Stone Mountain
I had a breaker in the front go out on my 345. I had the rear corner full and the compressor (not the problem) was in a wood box inside the curb-side cabinets in the bedroom.
-Fred
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 03-21-2007, 12:17 PM   #5
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
On our 345 the breaker for the compressor is mounted on the drivers side vertical frame inside the front hood. The compressor it's self is in the lower cabinet curb side rear under the drawers.
I can get some pictures if needed, Rob
Robfike is offline   Reply With Quote
Old 03-21-2007, 12:28 PM   #6
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I too have bag problems, is there another fuse besides the one at the
compressor? Mike
Mike Leary is offline   Reply With Quote
Old 03-21-2007, 12:32 PM   #7
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
Our's is in the right rear compartment (inside). Of course,it only fills the rear bags. The fronts are filled manually via schraeder (sp?)valve.
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 03-21-2007, 12:34 PM   #8
Mike Leary's Avatar
Images: 11
There was a recall for the '83 mohos & leaf springs were added, so no bag
damage would occur & prevent the "leaning" so common to the GMCs.Mike
Old 03-21-2007, 12:57 PM   #9
ViewRVs's Avatar
1977 20' Argosy 20
There are three breakers in the front. From the front, open the engine door. On the firewall to the right there are three little rectangular boxes with two posts and wires on them.
This is from the Stone Mountain thread.
Originally Posted by rdm
Brett
On the 325 and 345 there are circuit breakers on the fire wall
three breakers 2 30 amp and one 50 amp.
the power seats and the air compressor are on the same breaker usually the bottom one of the three. this breaker is a 30 amp breaker
they are located next to the isolator in group of three
TOP a 30 amp on top that has the start assist, floodlight and brake control for the tag axle.
MIDDLE a 50 amp connected to the isolator and the main solenoid for the coach batteries.
BOTTOM a 30 amp connected to roadside power seat, curbside power seat, air compressor for air ride
thanks hope this a help
Ray
We had this learning lesson earlier this year
Peter and Brett our trip is going great air ride is working OK
Fred H.
Old 03-21-2007, 02:34 PM   #10
Mike Leary's Avatar
Images: 11
Thank you all for air bag info; the '83 310 has the isolator , but no fuses.
Please, don't make me crawl under the dash!!!!!!
Mike
Old 03-21-2007, 07:02 PM   #11
str8strm's Avatar
I love this site! Somebody else asked the questions, but I learned at least two things that I didn't know. Thanks guys.
AIR 7992
Old 03-30-2007, 01:15 PM   #12
Chuckles's Avatar
Iwerne Minster , Dorset. UK
That's very interesting..... I have leaf srings on the 310, albeit with the rear part of the spring very crudely cut off! is that standard.....
It looks like the spring was "shortened" so the air bag suspension regulator frame work and the fuel tank had some "breathing space".
Do you know the content of this recall
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Old 03-31-2007, 08:16 AM   #13
Mike Leary's Avatar
Images: 11
Air bag madness
I believe the recall was government mandated... yes, if it looks like some
fool did the cutting...that is the "factory recall workmanship".
avoiding tire flat spots thedakotakid Tires 3 07-08-2003 04:48 PM
Front airbags thenewkid64 Mechanics Corner - Engines, Transmission & More... 22 07-06-2003 11:23 AM
Flat Head Rivets on bannana wrap? Bryanhu Belly Pans & Banana Wraps 16 07-04-2003 08:45 PM
Airbags and Towing with Car mcostanzo Tow Vehicles 0 07-02-2003 02:40 PM
Flat tire detector Pahaska Tires 6 08-08-2002 06:38 PM
