Old 06-05-2006, 11:59 AM   #1
Whipsas270's Avatar
1984 27' Airstream 270
Benbrook , Texas
Air suspension
Well here we go..... with all the new suspension controls out there would it work on my 84 Excella270 to use a f/b/s/s control and if so would that eliminate the tank. Most systems I have seen have compressor to bag inlet but no tank. only thing good on mine is from the tank to rear bags including the bags.
Whipsas270 is offline   Reply With Quote
Old 06-05-2006, 01:00 PM   #2
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
I think you would have a hard time finding something that would work with the weight of the motorhome along with the specific setup for a P30. Don't these systems require a lot of fabrication to replace the stock suspension? Not sure on the tank. I think a system that large would still require an accumulation tank based on the sheer volume of air required by the system.
I think simply repairing your factory system back to spec would be a cheaper choice.
Having said that - it would be cool to see how a project like that turned out in the end. Trying to imagine seeing a slammed 270 in the campground.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 06-09-2006, 01:24 PM   #3
Whipsas270's Avatar
Benbrook , Texas
Unhappy Air suspension
OK .....I posted this on the "classic motorhome" forum but got nothing so here goes.
My air suspension is bad from the accumulator tank up to and including the compressor. The lines from tank to rear are good rear bags and self adjusting valve are good. I will replace the front bags(independent from rear system).
My question is...could I replace the compressor and tank with a modern compressor and hook up the front bags to the system and use a f/b/s/s control?
All the modern systems seem to come with everything except an accumulator tank. This leads me to believe that the compressor doesn't need a tank.
Every day is a holiday!
84 Excella 270
95 1100 ACE
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Front airbags thenewkid64 Mechanics Corner - Engines, Transmission & More... 22 07-06-2003 11:23 AM
rear air suspensiom problems wb13798 Airstream Motorhome Forums 19 03-03-2003 07:12 AM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
air horns uncleneal Airstream Motorhome Forums 1 08-16-2002 07:22 AM
