Old 07-09-2010, 05:24 PM   #1
1986 34.5' Airstream 345
Carleton , Michigan
Air ride suspension P30 chasis
Does anybody know what size or part # air bag to order for rear air ride suspension? I,ve got a 1986 345 series, an have to replace both rear bags. I,d like to have new ones in my hands befor I remove old ones. An by chance is this an extensive task? I have a tag axle..Thanks RJ
dragonmantwo is offline   Reply With Quote
Old 07-09-2010, 09:38 PM   #2
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
Hey Dragon, take a look at this DIY that I did on my air bag replacement, and bushing replacement of the American Carrier Equipment system. This was on my 310, but think that you have the same carrier system with different control system.
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 07-10-2010, 10:50 AM   #3
Hello RJ i have posted and article on here with alot of part nos etc
when you have the new bags, airfittings and four new upper securing bolts, if you have any trouble getting over the top to the upper bolts, you can cut the rubber bags out then grind the rivnut fittings away carefully and whats left of the bag will drop away. I ended up removing the grey water tank, and wished i'd done it the way i just described . . . would have saved me hours of time
moonshine is offline   Reply With Quote
Old 07-30-2010, 07:38 AM   #4
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Hello, RJ - before you go into this any further, check that the problem really is the bags themselves. I saved myself untold $$ and work by discovering that the height control valve was leaking which let the bags empty out over an hour or two. Good luck.
Jamie
jking is offline   Reply With Quote
Air Ride Hitches ShikariJones Hitches, Couplers & Balls 96 10-08-2009 01:58 PM
Rear air ride suspension katytx General Motorhome Topics 4 09-15-2009 04:03 PM
air ride hitch cadonnelly Hitches, Couplers & Balls 11 12-04-2005 11:01 AM
Air Ride hitch? maznblu Hitches, Couplers & Balls 1 10-10-2003 08:46 AM
automatic ride suspension yargseth 1997 - 2004 Bambi 1 09-26-2003 09:02 AM
