Old 03-11-2008, 07:18 PM   #1
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
Air pressure dash gauge
Does anyone have an easy way to figure out why my dash airpressure guage does not show any pressure on my 89-345LE with a 454? I assume the sensor is on the tank, but don,t know. What is the simplist test to determine where the failure would be? I do have pressure in the bags and still have air horns and system seems to be operating OK!
Thanks in advance
raveson is offline   Reply With Quote
Old 03-11-2008, 09:59 PM   #2
Thanks in advance
There is going to have to be some kind of pressure transducer and it is most likely mounted back near the tank or in the compartment where the compressor is. I'd start there and see if you can trace the wiring from that point.
I'm guessing here but I would imagine that it will have one wire that heads up towards the front of the motorhome.
Unfortunately thats about all the clues I can give you.
Good luck!
Can you run both Air Conditioners with the Genset? Keyair Classic Motorhomes 4 08-26-2011 05:32 PM
Land Yacht Dash Air DonaldW Land Yacht/Legacy Motorhomes 25 07-21-2011 07:48 PM
345 Dash Air 1987_345 Classic Motorhomes 1 07-18-2011 06:31 PM
Air suspension connection warrenivan General Motorhome Topics 4 06-09-2011 03:43 PM
Air pressure 23 ft 09 international tmarquis On The Road... 3 05-13-2011 08:38 AM
