Old 08-28-2007, 11:12 AM   #1
jagcb750's Avatar
1986 30' Airstream 300
B , Louisiana
air lift assist for front springs
I noticed today that under the front hood of nancy, there was a little air pressure guage. no air pressure in it. So I went through my documentation and found a package wrapper that stated that it was an air lift assist for the front suspension to aid in the wear of the front springs. Anybody got one of these. Do you just add air with an air compressor. How much?
jagcb750 is offline   Reply With Quote
Old 08-28-2007, 12:51 PM   #2
Robfike's Avatar
1999 36' Land Yacht Widebody
Spencer , Indiana
Front air bag pressure
The front bags should have 55psi each.
Rob
Robfike is offline   Reply With Quote
Old 08-29-2007, 11:08 AM   #3
1982 28' Airstream 280
Norfolk , Virginia
The air bags are located inside of the front springs. If they do not inflate, there is a procedure in the forums on how to replace them with out taking the springs off. When you read the instructins, you think it will never work, but believe me, it does.
Steve
Geophilist is offline   Reply With Quote
Old 08-29-2007, 03:05 PM   #4
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Yes, you just fill them with air up to 60 pounds but fill them slowly they can blow up if over-inflated and the noise will sound like your coach exploded. I use a 12V compressor which puffs along to get the bags up to the correct pressure. The advantage to this compressor is that I can check the bags pressure st a campground and fill them before we leave in the AM. I will keep the pressure at 55 to 60 for interstate driving and drop it down to 50-55 for secondary roads. This gives us the best ride and best control.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 08-29-2007, 07:58 PM   #5
jagcb750's Avatar
B , Louisiana
There is a little air pressure valve under the front hood, so I will try to fill thebags up from there. Thanks for the useful support posting.
Old 08-31-2007, 09:13 AM   #6
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
our valves
We have 2 schraeder valves that come up on the front bumper. I think you should have a separate valve for each bag
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 08-31-2007, 07:07 PM   #7
jagcb750's Avatar
B , Louisiana
@str8strm: Thanks, I will check for those too!
Old 09-01-2007, 06:44 PM   #8
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
I blew one up once. Sounded like a bomb. I now use a small compressor from WalMart for the front bags instead of the high pressure air lines at a truck stop.
Kabooom!
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 09-03-2007, 07:21 PM   #9
jagcb750's Avatar
B , Louisiana
Well, I put 50 psi in them for now and it seems like they are holding fine. I will check them again soon to see if it is still holding air. Thanks for the help!
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Mystic Springs 2003 rally!! thenewkid64 Forum Rallies & Meet Ups 41 04-02-2003 04:52 PM
rear air suspensiom problems wb13798 Airstream Motorhome Forums 19 03-03-2003 07:12 AM
Heater and Air Conditioner jberndt Airstream Motorhome Forums 2 10-22-2002 07:45 AM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 09:33 AM
