Old 07-11-2013, 05:28 PM   #1
la nomade's Avatar
2018 22' Sport
stanfordville , New York
air conditioner: what to do about leaks?
it was 92 degr and i had to put the front ac on, the rear one leaks..but now the front one leaks again after i re routed the drain,so it took it all appart this afternoon to dicover that its actually the platic holding pan that is leaking at the connection to the tube,the whole thing seems to be desintegrating at the joint,what to do???i am in nova scotia right now,its beyond my fixing it myself,so the question is are those ac special to the A.STR or standard???can a rv place here replace that part,or is it a air str part???Coleman??????would like to know before i call around .....it should be fixed just in case climate change acts up again....such hight temp here are unheard of.....
la nomade is offline   Reply With Quote
Old 07-11-2013, 08:45 PM   #2
1991 30' Airstream 30
Lake Luzerne , New York
Hello MV - I suffer also from leaking A/C (rear unit) and went up on the roof to search for problem. Removed the cover and couldn't find anything that appeared broken, missing, etc. I believe the pan portion that the A/C sit on is a standard part (plastic pan) that is not specific to Airstream but rather specific to the brand of air conditioner- Dometic in my case. Hope you can stop by your return home. JM
ADK Jim is offline   Reply With Quote
Old 07-11-2013, 09:24 PM   #3
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
As a non-technical person and speaking from sad experience over the last several months, only one AC unit on the market has the capability of the internal drain system used by A/S to avoid condensate running down the outside of your trailer: a Dometic, but be sure your supplier knows A/Ss and query that issue vigorously. I mentioned that issue to a non-A/S RV person and he went ahead and installed the wrong one anyway. I should have pursued it more carefully. Good luck and hoping for cooler weather ahead!
Vivian
Richard and Vivian
Caliban The Wonder Dog: gone but not forgotten
Cerberus
Too many vintage A/Ss...
Landshark is offline   Reply With Quote
Old 07-11-2013, 10:55 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Get some silicone tape. It stretches, seals some leaks and is easy to remove.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-11-2013, 11:15 PM   #5
2009 19' International
San Marcos , California
I have the same leak around the discharge tube at the bottom of the drain tray. Once i cleaned away all of the airstream applied sealant, it looks like the clamp was installed too tight and or the plastic has become fatigued. Anyway it leaks at the tray tube. There is nothing wrong with the internal wall drain. I applied several coats of sprinkler pipe adhesive and have fused the plastic cracks. No leaks. Will also reapply some sealant all around the clamp and drain tube like airstream did just to make sure.
rstream is offline   Reply With Quote
Old 07-12-2013, 10:14 AM   #6
la nomade's Avatar
2018 22' Sport
this morning i called a rv place they are too busy to take this on they said....went to the local Ford dealer who does my oil change and checks everything before i hit the rd and they suggested to give a call to this A.C.repair company who actually comes to you and fixes a.c.so i am waiting for them to come next week,better this then my putting a band aid on...will have them look at the rear one as well...and will report as to what the solution was...apparently Coleman is pretty standard....thank you for your input....M
Old 07-12-2013, 01:25 PM   #7
1989 34.5' Airstream 345
Silverton , Colorado
Hmm...we just had both roof units replaced(Coleman to Dometic), and the pan for an AS IS different(had to wait for the second pan to be delivered). The ac's work fine, so far, and are MUCH quieter...we never could get both units to work at the same time, though the wire-around and switch were there. Now, both run with the gennie powering...haven't tried a landline yet. The pans are curved to fit.
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 07-13-2013, 12:31 PM   #8
la nomade's Avatar
2018 22' Sport
a.c
my A.C ,when i want them both to work at the same time do so only when the generator is on, otherwise i have to choose front or back....will pass on your info to the repair man and then let you know what was done...thanks..M.V.
Old 07-16-2013, 08:18 AM   #9
la nomade's Avatar
2018 22' Sport
the repair man came and basically was useless,he works mostly on the cooling part,he did put some silicone stuff on it, there is a big a hole in the plastic tray near the connection and said it should be rebuild with fiberglass tape????anyway, we are having another heat wave, its on,and leaks into a medium size garbadge can....so back to where i started..thinking of opening up the rear ac and see where the leak comes from there,maybe its a less severe situation...hopeful thinking..it definitly is a cracked plastic problem....
Old 07-16-2013, 12:45 PM   #10
1988 32' Excella
Robbinsville , New Jersey
The air conditioners are standard, but the drip pan is Airstream only bought from Airstream dealers or the Airstream factory. There are "drip kits" made by AC manufacturers that can replace the drip pan from Airstream (must remove AC to install).
Old 07-17-2013, 06:35 AM   #11
la nomade's Avatar
2018 22' Sport
that is very depressing news...costly...for now i will persist in sealing it the best i can and if it leaks i will just put the garbage can to catch the drip!!!!
Old 07-17-2013, 07:05 AM   #12
1984 31' Sovereign
1978 Argosy 24
Zavalla , Texas
Getting a car body kit that has some fiberglass cloth in it (Bondo is one maker) and applying the cloth with the resin and harder may get you sealed up. Cut the cloth in strips to apply. Another option, if you can get to it, may be to put JB Weld over the problem areas .... a little sanding would help it to adher. Good luck.
Orlop is offline   Reply With Quote
Old 07-17-2013, 07:36 AM   #13
raveson's Avatar
boca raton , Florida
You can get both air units to operate on shore power. Check back into my threads, there is one that shows how to wire for a second 20 amp cord to the power pole. Running both is the only answer to staying cool in heavy heat. The instructions are for a product no longer available, but the conversion can be done easily. Put mine in 8 years ago and no problems.
raveson is offline   Reply With Quote
Old 07-17-2013, 08:35 AM   #14
Wetaskiwin , Alberta
I am with Orlop on the fiberglass kit from car or boat store or hardware. Very easy to use. Make sure you get one with the WOVEN as opposed to randomly laid fiberglass mat, much easier to use. Make sure you clean well with acetone or cellulose thinners first over the area to be glassed, leaving a good margin. Wet the surface well with the resin, then lay down your sheets making sure they are pressed well down and saturated with resin..... no rolly bits rising above the surface. 2 or 3 layers will be all you need. On the back I`d be tempted to use a length of Eternabond tape, if you have any around, but since there won`t be much flexing, this is optional.
You will have to work quickly in the coolest part of the day, as the resin goes off at amazing speed once the hardener is added, so have all your cloth sheets cut to size before starting. (I like to cut small squares or strips rather than larger pieces the size of the job, since it`s easier to lay and saturate small strips) Use a small, short, stiff brush.... I usually take about a 1" paintbrush and use scissors to cut it down to half its original length.
You`ll be able to use the air conditioner a couple of hours later.
Penmaenmawr is offline   Reply With Quote
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Removing privacy curtain so air conditioner can be removed saltrm1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-11-2013 05:26 PM
Dash Air Conditioner Problems Santart Land Yacht/Legacy Motorhomes 4 09-05-2012 01:54 AM
Air conditioner cover havec1 Roof Vents, Skylights & Fans 4 08-12-2011 09:35 AM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
